YS 170CDI mount
YS 170CDI mount
Hello folks, I am thinking about getting a YS 170CDI from Singapore. I would like to know which of the mounts perform better, YS, Hyde, ...?
Thanks for your replies
RE: YS 170CDI mount
Thanks Tuny. That seems to be the common opinion. I have been reading a few post on 2x2 pattern planes and most seem to prefer it.
RE: YS 170CDI mount
There are some new Hyde mounts on the market that have been specifically specificalyl developed using the CDi engine and incorporate internal limters to prevent airframe strike. I think they are now available on the Central Hobbies site.
Keith
Keith
My Feedback: (45)
RE: YS 170CDI mount
LR-85 is the new limiter mount that I'm using on the CDI. At idle the engine is virtually hard mounted, but this prevents any unwanted kickbacks and such. You will see more movement of the airframe at idle that before, but as soon as you advance the throttle it smooths right out. This also helps the idle on the CDI as the engine isn't moving much. When doing some testing on the CDI with the AR-80, the engine would move enough at idle that the throttle would close slightly with each bounce and wouldn't allow me to get the idle in the 1400 or below range. The LR mount fixes this. I have actually gotten it to about 1200, but I don't fly it there. I fly in the 1400-1500 range,
Arch
Arch
RE: YS 170CDI mount
hi thanks
What about the noise, ar 80- lr85 and if you have try YS mount,what you prefer,?
do you have any ide,, when the limiter begin to works..? 2000omdr???
RE: YS 170CDI mount
Thanks all for your input. I think I am going to pick up the YS mount since it's available at the same store in Singapore. Also I have mostly read positives about it. Somewhere in the forums, I read that some simple maintenance in YS mount is required after 150 sorties.
RE: YS 170CDI mount
Brett has used both and Arch is right, use either one. However, we found that for a firewall mount the Hyde actually is a little lighter because no adapter is required. If your plane has the rails in the nose for a mount the YS is the lightest set up.
RE: YS 170CDI mount
If you are using the YS mount, be sure to leave sufficient gap 2 - 3 mm to allow the engine to move backwards when applying your starter. Otherwise the spinner will contact the nosie ring of the model when pressing the starter.
Keith
Keith
RE: YS 170CDI mount
Wow, that's interesting, something tells me I would have found the spinner issue (hitting the nose) the hard way if not for the post here. Thanks guys. Do you know if the "CARF Integral" has rails in the nose? Also how to go about if the model doesn't have rails. Then do you use a hard mount first and then mount the YS style mount on those rails?
RE: YS 170CDI mount
No, CARF Integral does not have rails in the nose, neither a firewall. You have to make your own mounts. Check the below link, Ivan Kristensen posted the pictures of how he did the rail mount for YS 170 CDI in his Osmose.
http://albums.phanfare.com/5187035/3...ageID=70210018
I hope this will help to solve your problem.
Nedim
Nedim
