RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Spectrum 10 (https://www.rcuniverse.com/forum/rc-pattern-flying-101/10851606-spectrum-10-a.html)
randy10926 12-09-2011 09:38 AM
Spectrum 10
Anyone try this transmitter yet?
Ryan Smith 12-09-2011 09:46 AM
RE: Spectrum 10
I've had one for a while. What would you like to know about it?
highfly3D 12-09-2011 10:39 AM
RE: Spectrum 10
is this transmitter only for tray users....:D
Ryan Smith 12-09-2011 11:00 AM
RE: Spectrum 10
No, it is designed to work without a tray. There are two retractable arms in the rear of the transmitter that pop out and attach to the strap/harness. I'm sure you could use it with a tray, but it doesn't require one.
randy10926 12-09-2011 12:24 PM
RE: Spectrum 10
How does it compare to the spectrum 8?
Any neat stuff for pattern?
How well does the 'tray' work? Have you tried a set alone tray?
I need to go 2.4 and the 8 and 10 are what I am looking at.
highfly3D 12-09-2011 10:53 PM
RE: Spectrum 10
What i have heard from many people that this transmitter is specially designed for European style tray users.. so i stopped thinking about this radio as i dont use tray... :D
I would like to see some pictures of this transmitter were people dont use tray..
Ryan Smith 12-10-2011 01:09 AM
RE: Spectrum 10
1 Attachment(s)
Randy,
There are several ways I can go about describing it. I guess a comparison between it and the DX8/any normal handheld transmitter would be the best comparison. I wouldn’t say that the differences are negatives, but this type of radio is substantially different from anything that you probably have ever flown. I can give you some basics on the radio, but we are still in the testing phase, and there are features that are added and things changed around in the code as the testing program progresses. It’s nothing major, and nothing bad, but there is a lot of information to sort through there and everything must be tested. For each version of the code, there is a 25-page checklist that needs to be evaluated and each page is full of features/items to check.
Compared to the DX8, the programming is much more powerful. It’s a Mr. Potatohead transmitter of sorts, so there is quite a bit of assignability. The top two corner switch modules can be changed out with a different arrangement so that you can have quite an array of switch locations. I think that is a very cool feature, and is typical of most tray style radios. These modules actually tilt about 30-degress, so you can adjust them to where you are comfortable. The downside to it is that sometimes they can be a little hard to reach, especially if you are using them to switch rates back and forth. The upside is that the design of the radio minimizes the need to use rates. It has nine mixes, and all six of the programmable mixes can be either linear or point-curve mixes. I use point curve mixes on pretty much everything except a low throttle → down elevator mix. Many transmitters only have some of the available PMIXES as point-curve mixes.
There are multiple throttle curves (I can’t remember off the top of my head how many) that are assignable to either be on all of the time, or to a specific switch setting or flight mode. I can see that being an interesting feature, especially for electrics (I used two curves when setting up some of the Schulze ESCs for the use of the proportional braking). The buttons on the sticks have assignability to them, so you can use them to cycle between rates, or for retracts or flaps (not really pertinent for pattern purposes, but I fly a lot of scale stuff at work as well), and that makes it so that one doesn’t need to remove their hands from the sticks to access some of the features. This circumvents the slight difference in ergonomics of this radio compared to a handheld transmitter.
I feel like I am missing some of the features, because they are numerous, but mostly because there is nothing that is limiting it from being fully functional as a pattern radio. It is more functional than most people will ever need it to be. Some of the other features that may be less obvious for its use in pattern are the ability to switch seamlessly from mode one to mode two, full digital trims and sliders, SD card for ease of updating/transferring model setups, backlit screen, built-in telemetry, solid rotating antenna (it folds back into the transmitter itself for storage, to prevent damage; it’s a different design and not like the typical JR/Spektrum hinged antennas, it’s about a four-inch long blade style- I think it’s cool!), Preflight checklist, auto trim feature (instead of trying to trim with the trim lever, you can hold the stick approximately where it needs to be for level flight and push one of the stick buttons to set the trim for that stick), adjustable assignments for the switches, tons of wing and tail setup types, timer that can be set to a certain throttle position to activate, and built-in charger among other things.
As I said, this radio has quite a different feel to it, and will take you some time to get used to. I would recommend putting in a smaller airplane that you don’t mind being dinged up (ParkZone T-28s are the best!) to get used to the amount of stick travel is required, especially for landings. You will need to move the sticks much farther than you are used to. They are easily twice as long as regular transmitter sticks, so keep that in mind. The upside to this is the fact that you can be much more precise in the air. There is much more resolution, if you will, and you can be very precise in your movements. This negates the need for using very many rates, or different expo because it really just works itself out. You can move the stick quite a bit and not get a huge effect, so it’s comfortable for me to use no rates and fly an entire sequence.
As I said, I have flown this on many different types of airplanes, not just pattern airplanes. The group of people that have these radios now (select internal Horizon employees and Team Horizon members) have to test all of the features and their interactions with other features to make the code as bulletproof as possible. When it comes down to it, pattern airplanes are relatively simple in terms of programming power required to fly. Scale airplanes, on the other hand, require much more features and programming power, because they just don’t fly well. That being said, most of the airplanes I have flown with this have been scale airplanes that are complex (flaps and retracts, multiple servos per surface, etc.) that also require mixing to fly properly. I have flown the radio in one of my ExtremeFlight 48” Vanquishes, and will probably put it in my Prophecy next year. For what little pattern practice I have been doing, I’ve been flying 11Xs, as that to me is the perfect F3A radio. AC Glenn was practicing for the Nats this year with his DX10T, but ended up not using it at the Nats because it was a prototype radio and he wouldn’t have had a backup radio should something happen to his primary. He really liked the radio a lot and probably has more pattern flights than anybody else with the radio. I would say he had upwards of 75-100 flights on it. I haven’t had a pattern airplane airworthy in quite some time, and this year was bumming whichever Visa he wasn’t flying to get a fix, and I flew the Visa on the 10T a couple of times and loved it.
If you can get around it looking like a box, and the layout being different from what you have flown in the past, it’s really a very good radio and honestly is optimized for precision flying.
The DX8 is my every day radio. This is our in house “working man’s” radio, and we use it for almost every airplane that we develop within E-flite, ParkZone, HobbyZone, Blade, and Hangar 9. I have a lot of experience with the DX8, and its programming is a stripped down version of the DX10T’s .The biggest negative that I see for it in pattern is that it does not have any point curve mixes and it does not have a digital throttle trim. I have to have an analog throttle trim, or some way to mimic it because no engine will run so consistent that you never have to adjust the throttle trim. It’s a pain for electrics because I like to use a flight idle, and have the motor turn over as slow, or almost as slow its able (depending on the output of your ESC). To get an ESC to initialize, you have to be below the output that causes the prop to spin, so you have to back down off the setting that you landed at and then bump it back up. It takes forever, and you can somewhat augment that by increasing the trim steps, but you relinquish your ability to fine-tune your idle, particularly noticeable with better ESCs like a Jeti or a Castle. Digital trims on the throttle are practically useless for turbines because the throttle trim is moved all over the place to preset locations for the startup and shutdown sequences. I must add the disclaimer that the DX8 was designed to be used for mode one or mode two without the need for a different radio altogether, similar to the DX10T. This is one of the driving factors behind the digital throttle trim.
The DX8 is a fantastic budget, middle high-end radio that offers many features. Some people don’t mind the lack of point-curve mixes, but for me it limits its use. The rest of the radio has the functionality for use as a pattern radio, as well as its feel, but for the price point of the electronics and the intended market, it wasn’t seen as a necessary feature. I didn’t start using radios less than the highest levels that JR offered (I bought my 10X after having been flying for only about a year, followed by extensive use of the 93/9503, 12X, and 11X). I will say without a doubt those are the two things that I do not care for regarding the DX8, other than that, it’s a solid radio. Some people may not be bothered by this, and if you are flying a good enough airplane that is setup properly, you may not need the advanced mixing features unless you are flying some crazy sequences. Even for use in Masters-level sequences, provided you are flying a good design, this shouldn’t be a detriment, because truthfully, Masters sequences really aren’t that demanding. There are no rolling radii, and snaps are much sparser compared to F3A.
The DX8 also features a backlit screen, throttle curve, SD card, and built-in charger, and timer that can be set to throttle position to activate.
The other advantage is that the terminology and essential programming are similar to what you are used to with JR. The menu architecture is different, and all of the servo functions (ATV, reversing, speed, sub-trim) are in one menu, versus each of them being in their own entity in the main menu.
If you are looking for a traditional, handheld transmitter that is very functional, doesn’t break the bank, and will probably be the last transmitter you’ll ever need is the JR 11X. A lot of people poo-poo on it because of its appearance, but it’s a fantastic radio. I flew 10/12Xs almost exclusively for about 9 years and loved the feel of that radio series. This radio has a different feel to it, but I absolutely love it. It’s got about 90% of the features of the 12X, some features that the 12X doesn’t have, and it’s half the price. It and the DX10T are very comparable radios in terms of programming power and features. The 10T has a little more programming power because of the requirements based on its design, but overall they are quite evenly matched.
I feel like I am skipping around, but there is so much to say about these radios. It’s also very late and I have typed three whole pages in a Word document to describe the radio, so I am about ready to turn in. If you, or anybody else thinks of something else to ask about the radio, please tell me and I will do my best to answer it. If anyone would like shots of the radio, or the screens, please let me know and I will get those as well.
Also, there seems to be some confusion regarding the radio being a “tray” radio, and requiring a transmitter tray to use it. If you have large hands, you can hold it conventionally and fly it. Negative snaps for mode two users could prove to be interesting, but it’s designed to be used with the included harness and to be flown with the thumb and forefingers, not thumbs only. At the risk of ridicule for the rest of my life (not that it didn’t have its genesis during my infamous “Goober” years in D2), here is a picture, albeit taken from a iPhone, by one of the Spektrum engineers of me at SEFF this year in an attempt to embarrass me for circulation around the office, demonstrating the proper usage of the radio. As you can see, it lends itself well to a pattern stance, and you do look sophisticated flying it; provided you are barefoot, and are wearing plaid shorts with a glow in the dark blue shirt. The strap is a little kinky, but hardly imposing once you become accustomed to it. I must admit, it felt like what I would imagine wearing lingerie feels like the first time I strapped that bad boy on. My wife looks at me funny because I can put it on so fast, but I also got the same looks when people saw a 6’4”, 250lb brute gracefully and swiftly get into the front seat of a Super Cub back when I was flying full-scale a lot.
I hope this post was helpful. I’m glad this radio has generated some interest. I honestly never thought I would like a tray radio, and have said nicer things about men who own cats in than I have about men that fly with an MC-24, but in addition to boosting your street cred, it’s a match made in F3A heaven. I’m honestly surprised that the use of these types of radios hasn’t matriculated into mainstream use for precision aerobatics. Hopefully, this will help change that.
TonyF 12-10-2011 06:02 AM
RE: Spectrum 10
Surprised you're not using the throttle cut or throttle hold feature in the DX-8, and for that matter nearly all the current radios. I hardly ever touch the trim now. All you have to do is activate throttle cut, set it to -5 to -10%, select a switch position to have it on. I use the Mix 1 position. Then when you power up the system in the model, turn on the throttle cut and it will arm the ESC. Flip throttle cut off and you now have your idle trim setting. No need to ever move the throttle trim.
Wish I had been one of the selected Team Horizon members. I used to fly a tray many years ago. And so far this year I have logged 2,500 flights on a wide variety of stuff. I have a lot of time to fly!
randy10926 01-06-2012 07:37 AM
RE: Spectrum 10
I really would like to try a tray radio. I fly thumbs/fingers and have started feeling holding the transmitter is cumbersome. Having to move the sticks more sounds great to me. I have also found that the throttle curves are very different and important of the little E-power I have flown.
Sounds like a 10 is what I want for the vanquish 2m. Gee it is nice to have all the kids out of college so I can upgrade and still eat.
I think I need a special outfit like that to fly in :-).
randy
desertrider49 01-06-2012 08:50 AM
RE: Spectrum 10
Last fall I bought a DX8 and it has worked fine for my electric pattern plane. However, last week I programmed it to my 40% gasser and found a disturbing element. When at idle and I put a little pressure on the idle stick, the rpm changed. There seems to be no hard stop on the gimble.
Do I need to send the radio in for repair or is that normal ?
Hope this isn't too far off topic
Randy
desertrider49 01-07-2012 11:10 AM
RE: Spectrum 10
ORIGINAL: desertrider49
Randy
I talked to one of the Horizon guys at the AMA convention here in Ontario California yesterday and asked him about my radio. His reply was, yes he knew about the gimble and that I should try to tighten the gimble and activate the ratcheting on the throttle. Not the answer I wanted to hear. I guess I'll be going back to Futaba and throwing the DX8 in the trash.
As one of my buddies was holding the 10 I reached over and the throttle stick did the same thing. Just sayin' really look it over before you spend that kind of money.
Ryan Smith 01-07-2012 03:06 PM
RE: Spectrum 10
It probably has something to do with the fact that the radios are capable of doing Mode 1 and Mode 2 in the same radio. I'm not sure. Do you remember who you talked to?
When you said the RPM changed, I presume that you meant that when you gave a little pressure against the stop, the throttle lowered?
Doug Cronkhite 01-07-2012 03:54 PM
RE: Spectrum 10
I think you'll find that all radios do this. You can easily put enough pressure to overdrive the gimbals on pretty much any radio on the market.
desertrider49 01-07-2012 03:59 PM
RE: Spectrum 10
ORIGINAL: Ryan Smith
I didn't see his name, I don't want anyone to get in trouble.
Yes, the idle goes down with pressure. I adjusted the throttle to not stall with the pressure, but the idle is too high for normal flying as in stall turns and spins.
desertrider49 01-07-2012 04:05 PM
RE: Spectrum 10
ORIGINAL: Doug Cronkhite
No, as I sit here at my computer I can touch my 8 +/- year old Futaba 9c that is used for my simulator that has been dropped, has switches broken, but the gimble is better than the new DX8.
NJRCFLYER2 01-08-2012 01:56 AM
RE: Spectrum 10
There is away to eliminate the end travel response.It takes a little back and forth between setting travel percentage and sub trim, and I guess it limits the option for a "throttle kill" position, but here it is in case someone finds it useful.If you leave travel at 100%, when you go into sub trim on my DX8, it requires a 162 point adjustment to get it to where the "expected" stick movement does what I want, but will not cause any servo response if extra pressure in the low throttle direction is applied. If youincrease the trottle travel response percentage towards idle, you will have to re-adjust the sub trim by decreasing it.
It works this way because thereare pre-defined upper and lower limits to pulse width range, roughly 900 µs to 2100 µs, which is enforced in the encoder software. When you adjust overall travel percentages, you are simply widening the numeric range that the transmitter will apply for a given amount of stick movement.
For example, let's say that sub trim is "neutral" (0), and you pick a wide travel range that eats up 950 µs to 2050 µs for the full range of stick movement.We will ignore what the trim lever does just for the example. When you adjust the sub trim, you effectively shift a "window" that slides over the 900 µs to 2100 µs range, and oncean edge of that sliding window reaches a limit at either extreme, that's where the response to stick movement in that direction will stop. Clearly this isn't the ideal solution, but it may work for someone. Probably not what an electric setup requires, but could work with a CDI equipped slimer, provided that a choke and/or CDI kill capability is available.
BTW, on both of my 9511's, the throttle stick does the same thing, but in that case I mixed it out. Maybe that can be done on the DX8 too, but I am not as familiar with the mix capability on the DX8.
