RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Knife edge wing (https://www.rcuniverse.com/forum/rc-pattern-flying-101/10882450-knife-edge-wing.html)
patternflyer1 12-30-2011 12:03 AM
Knife edge wing
In the ama rule book...
6.6: Knife-edge wings are not allowed
So what is a knife edge wing?
Chris
Ryan Smith 12-30-2011 01:02 AM
RE: Knife edge wing
Poor description of prescribing a minimum LE radius? Isn't FAI's minimum LE radius 2mm or something?
Doug Cronkhite 12-30-2011 09:44 AM
RE: Knife edge wing
Yeah.. has to do with radius of the leading edge. It's not something related to knife-edge flight.
Scott Smith 12-30-2011 02:35 PM
RE: Knife edge wing
That rule was changed by a proposal from Tony F in the last rule cycle (I voted against it as I thought it was too vague)
6.6: Knife-edge wings are not allowed. Leading edges must have two (2) millimeters minimum radius.
Change to:
Intent:
In 34 years of competing in pattern I have never seen the minimum leading edge rule enforced. It is unnecessary for this to be in the rulebook.
The intent of this proposal is to simplify the rulebook and eliminate unnecessary wording.
Proposal passed 9-2
Ryan Smith 12-30-2011 03:02 PM
RE: Knife edge wing
But that rule without the wording is rather vague. If it's NEVER enforced, why not have proposed to remove it altogether, rather than generalize it to the point of not knowing what it meant without a history lesson? What was it hurting to have the extra wording in there? I've never seen it enforced either, and I'm not disputing it per-se, it just makes it more confusing. Knife-edge wing doesn't mean much to me.
Tony?
TonyF 12-30-2011 05:47 PM
RE: Knife edge wing
Sort of like the weight rule. Hardly ever enforced, so let's get rid of it.
Draw out a 2mm radius leading edge. There probably wasn't a model out there that would have passed the rule if enforced. The Contest Board is a very funny committee to deal with. Probably if I had tried to eliminate the entire rule it wouldn't have passed. But keeping the wording "knife-edge wings" and just eliminating the measurement got it approved by a 9-2 vote. Really a stunning victory. Maybe next time someone can propose to eliminate it entirely.
Ryan maybe?
Scott Smith 12-30-2011 06:21 PM
RE: Knife edge wing
ORIGINAL: TonyF
I took a hole punch to a business card...7.5mm diameter and it matched my Prestige stab. The wing looked like about 10mm diameter (5mm radius) at the tip. So the Prestige would have passed (and probably the Bravo as well.) Happy to hear we are able amuse you! ;)
TonyF 12-30-2011 09:06 PM
RE: Knife edge wing
I stand corrected. But I just checked a popular entry level model I have and at the wing tip it was smaller then 2mm. But what is the whole point? I have seen models with stall strips on them that certainly would not have passed if measured. It was a rule that long ago quit being relevant if it ever was. There are more rules like that in the book that should get the same boot.
With hindsight it could have been worded better. Maybe the CB could issue an explanation on what it means similar to the Masters Nats qualifying?
MTK 12-30-2011 10:08 PM
RE: Knife edge wing
ORIGINAL: TonyF
Tony's got a point. Having installed stall strips on thick winged sport jobs before to make them do better stuff, their radius was around 2mm or just under.
The rule implies that a "knife edge" wing will hurt more than one with a larger radius when the wing hits you. Absurd.....! It is a silly rule
cmoulder 12-31-2011 01:46 PM
RE: Knife edge wing
Call me crazy, but I'm worried more about the prop and the spinner.[:@]
MTK 12-31-2011 02:00 PM
RE: Knife edge wing
ORIGINAL: cmoulder
The rule implies that a ''knife edge'' wing will hurt more than one with a larger radius when the wing hits you. Absurd.....! It is a silly rule
Happy New Year Bob...
I actually completed the retrofit of Aesthesis with the Mintor 38 and took a flight today; only had enuff gas for one flight.
Unreal- Dec 31, north Joisey, 55F, no wind. Call ME crazy but that's about the best we've had in 10 years. Still remember last year same time frame....several extra days in hospital (knee replacement) due to the storm. A royal PITA getting back home
cmoulder 12-31-2011 02:20 PM
RE: Knife edge wing
Matt,
Happy New Year to you and all RCU friends and acquaintances!
Great to hear Aesthesis is up and running. I've been wanting to see that one flying for some time, but I know your Temptress is hard to beat.
Yes, a fantastic day for flying in our neck of the woods as well. I stayed at my small local field and flew the 62" Osiris and had a blast working on geometry for Advanced without the hindrance of wind. At least now I know what the figures SHOULD look like, lol!!
NJRCFLYER2 12-31-2011 07:21 PM
RE: Knife edge wing
ORIGINAL: MTK
ORIGINAL: cmoulder
5 or 6 years ago we had a warm spell here in early January, hit a little over 70 for a couple of days. Based on the latest data with us getting down into the mid 50's on Dec 31, I am about to start panicking that we're seeing the onset of Global Cooling. Or maybe it's just the Global warming induced Climate Change doing this. So confusing. Either way, I expect to see glaciers advancing through the area any day now.
Hey Matt, made a lot of progress on project X after we talked. Let's go flying tomorrow, before the glaciers hit! I feel the need to add my fair share of CO2 to start off the new year.
MTK 12-31-2011 08:47 PM
RE: Knife edge wing
ORIGINAL: NJRCFLYER2
I'm charging Aesthesis as we speak. Solberg?
NJRCFLYER2 12-31-2011 08:49 PM
RE: Knife edge wing
Well, technically we're not members anymore as of 1/1/12. How about Milford? Rt 209 is now OPEN!
NJRCFLYER2 12-31-2011 08:53 PM
RE: Knife edge wing
Better yet, let's go to Pocono for the 2012 Freeze Fly! There's hot food, as long as River Road is open.
MTK 12-31-2011 08:59 PM
RE: Knife edge wing
Milford sounds great.... We should try to go early. Windy in afternoon
Went to Jim's place yesterday and he filled me in on some intersting developments regarding he and Banshee. I'm sure he'll share. There was also a connection with the new movie "Red Tails", sequel to the Tuskegee Airmen. The man is living proof that one never knows who he may influence through flying toy airplanes well
NJRCFLYER2 12-31-2011 09:19 PM
RE: Knife edge wing
Jim is the reason I got interested in RC to begin with. He was at a contest at Mitchell Field back in the late '60s, doing his thing with the Banshee and I just knew right then and there that I wanted to do that too.</p>
NJRCFLYER2 12-31-2011 09:38 PM
RE: Knife edge wing
ORIGINAL: TonyF
Tony:
We generally don't agree on this weight controversy stuff, but when it comes to the 2mm LE rule, it does seem to be outdated. Not that this rule causes many problems, but what is the point of carrying this forward as a safety rule when the AMA allows up to 55 lb. stuff to fly? This is probably an easy rule proposal to effect a change, just to remove clutter from the rule book.
Ryan Smith 12-31-2011 09:46 PM
RE: Knife edge wing
I am probably shooting myself in the foot here, but I know for a fact that most of out UMX airplanes have a LE radius of less than 2mm. I think the rule needs to be eliminated completely as it is no longer valid with the micro airplanes we have available to us.
NJRCFLYER2 12-31-2011 09:50 PM
RE: Knife edge wing
Iguess Iwould need to really check the rule book, but if this 2mm thing is across the board, then we had better stop flying foamies so that no one gets hurt!
Rule proposal time!
klhoard 01-01-2012 07:55 AM
RE: Knife edge wing
Rule proposal time!
Yeah, and what about those indoor micro-film free-flight jobbers?
Somebody could lose an eye!!!
