RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Long Servo Leads (https://www.rcuniverse.com/forum/rc-pattern-flying-101/11153636-long-servo-leads.html)
jkruger 07-13-2012 05:35 AM
Long Servo Leads
Has anyon used long servo leads from servowires.com? I'm trying to avoid connecting several leads to rear mounted elevator servos in a Valiant.
cmoulder 07-13-2012 06:05 AM
RE: Long Servo Leads
1 Attachment(s)
Do you know how to solder?
If so, you could get a long roll of servo wire and use the male and female ends from 2 shorter servo extensions to make a 4-wire dual-elevator extension. The red and black are soldered together with their respective colors, with separate signal wires for each servo. In short, common power and ground and separate signal. I have done this a couple of times and it works great and makes for a neater installation.
Ryan Smith 07-13-2012 10:15 AM
Bob,
Are you stripping the separate signal wire off of another roll, or are you sourcing 4-wire ribbons?
Thanks!
Ryan
cmoulder 07-13-2012 02:11 PM
Ryan, yes stripping off the extra signal wire, saving the extra red/black for use as battery leads when needed.
I heard somewhere in the past that somebody makes 4-wire bulk stock for this purpose, but I have not been able to find it. If anyone knows where to get it I would like to know.
Another advantage of doing it this way is that one can customize the extension lengths as necessary and not have a lot of excess wire.
