Problem with CellPro Charger
One of my CellPro charger gives error message NEG TERM. < 0
The message apears after pushing the Start Charge button. When pushing the Start buttom "Wait..." message apears for about 2 min. then message come "NEG TERM. < 0" Message apears regardless if Pack is connected or not. Did anyone expirianced this? I got no response from provider and anyway I try to save the cost of shiping it to and fro. Thank you in advace Amram Leshed |
RE: Problem with CellPro Charger
1 Attachment(s)
Attached is the manual, in the troubleshooting section (page 18) it says that the black banana jack is reading below 0 volts.....I'm guessing it's the wire itself, maybe a bad soldier joint.
Amran
Do you get the same error using a different pack? What configuration are you trying to charge? Woodie |
Hi:
Sound like reversed polarity Rare.....very rare Regards Mario |
I get the error regardless type of pack I try to charge. Moreover, same maessage comes even if no pack is connected
Amram |
If you are using the outside jacks for the main leads, check to make sure there is continuity between the 2 center jacks. If there isn't any continuity, the fuse between the two center jacks is faulty. There is a thread around here somewhere about how to replace it with a common automotive fuse.
Woodie |
WRITTEN ELSEWHERE BY WOODI WATTSUP:
There are 2 common problems with the CellPro 10S charger. As Tony mentioned, the external fuse contacts can get loose over time and actually melt the fuse as the contacts loosen and the amps/resistance climbs. I would suggest taking the top off the charger and ensure the clips holding the fuse are clean and tight. Second, there is a fuse between the two center jacks on the top/front of the charger. Easy to test, just check resistance between the 2 center taps. If there is an open, that fuse is blown. If you look at the fuse, it looks more like a diode/resistor than a fuse but it is a fuse. If the fuse is open, you can replace it with an automotive type fuse. I can't recall what the fuse value is but will check and update this post. That tiny fuse (diode/resistor looking) inside/between the center jacks is rated at 15 amps/125 volts and can be purchased at Radio Shack for less than $1. I just had to replace mine, that's how I know! Everette WILL CHECK THIS |
1 Attachment(s)
Checked. Both Fuses are fine... Any other thoughts???
Amram |
Try to reloaad firmware. It is easy to do. Good luck,
Got official answer from FMA as follows:
Good Day, You should check the following: High Voltage - Diode Check, check continuity D10 - If bad, replace and check U2 for damage Output Section - Diode Check, check continuity D15, D16 - If installed, remove. These parts are now DNI Output Diode (Zenner) - Diode Check D18 - .34 - .37 / counts up open - If bad, replace ***also check underside of CB for burnt traces if bad*** Micro Processor U6 - Check pin 1 to ground, should read approx 44k. If bad, not worth fixing charger. Switch FET's - Diode Check Q15, Q16 - .5 / .52 = Good. If bad, both switches must be changed Q1, Q2 - .5 / .52 = Good. If bad, both switches must be changed Q11, Q12 - .5 / .52 = Good. If bad, both switches must be changed Q5, Q6 - .5 / .52 = Good. If bad, both switches must be changed Zenner Diode Check - Diode Check Q15 - .6 / .7 = Good. If bad, change D2 Q2 - .6 / .7 = Good. If bad, change D1 Q11 - .6 / .7 = Good. If bad, change D3 Shunt Check - Diode Check Q33 - .45 = Good. If bad, replace Power FET's - Diode Check Q28 - .5 / Count up high (1.4) If bad, change Q28, Q29, U10 Q29 - .17 / Count up high (1.6) If bad, change Q28, Q29, U10 Regardless of changing components and getting it to work, you have no way to calibrate the charger. This will present a safety hazard and do not recommend this. NOW I CAN GET TO WORK ON IT !!! :-) _________________________ I added cool smileys to this message... if you don't see them go to: http://s.exps.me |
