RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Score-sheet - No scribe !! (https://www.rcuniverse.com/forum/rc-pattern-flying-101/11569862-score-sheet-no-scribe.html)
serious power 07-15-2013 04:33 AM
1 Attachment(s)
Hi,
Some time ago we started to run our comps without scribes - because we had no other choice.
(This post is not about the rights and wrongs of this - there are both)
To help we designed score-sheets as per the example below.
The idea is that one just has to locate the tip of the pen anywhere in the manoeuvre box and write the score while still watching the model in flight.
Just thought we would share.
Brian
Anthony-RCU 07-15-2013 07:44 AM
RE: Score-sheet - No scribe !!
Neat idea but might make the scorers job a little tougher. In D1 most of us fold the score sheet vertically leaving the score column exposed. Keep your finger on the crease and keep moving down. When the pilot exits the box copy your scores to the score column. My handwriting is pretty bad and worse when I am not looking. This usually works fine as long I don't get to sloppy moving down.
