Temptation F3A
Is the Temptation a good airplane? I need some input here. :) Build quality, flying, etc.
Who is the manufacturer? I can get one slightly used without the electric setup and servos for about $325. I will still use a 10s setup if I decide to buy the plane. What motor do you recommend? Just want a 2x2 because my smaller Helios 63e fly much better than anything else I have, even than my 1/4 scale Extra 300. :) Regards Knut I. Skattebo Hvittingfoss, Norway |
I had one some years ago , good plane (dont think you get kits any more) what motor , I really dont know but I think maybe its a bit narrow in the nose for the new Hacker Q80's so I think any "normal" outrunner will do, maybe some off this "not" competiton Hackers or the Himax 210 it depends on you budget.
The plane I had was sold to a nice guy i Stavanger and its now over 10 years old and has around 800 flights and as I know still going strong. |
The old setup in the plane was with a AXI 5325. I don't know wich one of the 5325's.
If it's a good plane, I think I will buy it. I'm not into competition flying but I just like the way the pattern planes fly and like to fly precision aerobatics. -- Knut I. Skattebo Hvittingfoss, Norway |
If you think about schedules I think it will be perfect for Sport and Nordic you can get it through the Fai secuence to but it not ideal it flies a bit fast but its all about throtel management!
If you go with Axi see if you can find a one with about 200-230 kv for 10s , set it up with a Jeti and have fun , if you dont need down line braking its several choices I have had bad experience with Castel (makes a lot off noice at higher braking so no good) |
If its Jarans old plane, it flies very well. Have seen it several times with the Axi setup. Here is a link to the maiden flight http://www.youtube.com/watch?v=Oc_o76K9f78
Piedmount Models was the company, same company that put out the Brio and the Focus and Focus II.
Originally Posted by LS1f
(Post 11664417)
| All times are GMT -8. The time now is 09:57 AM. |
