RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   New Great Planes Sequence 120 (https://www.rcuniverse.com/forum/rc-pattern-flying-101/11602578-new-great-planes-sequence-120-a.html)
Fat Albert 08-09-2014 06:05 PM
1 Attachment(s)
Hey guys,
Ran across this while looking at Tower tonight. I couldn't find any details, but looks like it could be a great entry level pattern plane.
http://www3.towerhobbies.com/cgi-bin...?&I=LNEDWF&P=G
I also started this in electric pattern, but looks like this might be a better place since it says GP/EP
kenh3497 08-09-2014 06:13 PM
Nothing on the GP web site either.
Mike Cohen 08-11-2014 12:08 PM
Looks like they are introducing a whole lineup:
http://www.towerhobbies.com/products...del/index.html
flywilly 08-11-2014 05:32 PM
Interesting! The Apollo 70 and 90 are clearly different designs, both in fuselage and wing (plug-in versus one piece). They appear heavily influenced by
recent Japanese designs. I'll probably give the Apollo 90 a try:)
Fat Albert 08-11-2014 06:25 PM
More details
http://www.towerhobbies.com/products.../gpma1232.html
Wingspan: 71.5 in (1815 mm), Wing Area: 836 in[SUP]2[/SUP] (53.9 dm[SUP]2[/SUP]), Weight: 9.75-10.75 lb (4420-4870 g), Wing Loading: 27-30 oz/ft[SUP]2[/SUP] (82-92 g/dm[SUP]2[/SUP]), Length: 73 in (1855 mm) Requirements: Radio system with a minimum of 4 channels and 5-6 servos, 2-stroke 1.20 or 4-stroke 1.55 glow engine or 50-65-450 outrunner brushless motor, 80A (min.) brushless ESC, 22.2V 5000mAh LiPo battery & compatible charger
kochj 09-15-2014 05:43 AM
Looking at other designs of late, the sequence looks right on with the EF Vanquish.. That has proven itself to be very reliable flyer.
One could say the Vanquish is tech. an OLD name, but they didn't need to RE-invent the wheel. They tweeked the heck out of it..
The Sequence is a good 350$ less than the EF. I don't know anything about electric setups, but I believe the 2M setups use 10-12S LIPO???
I hope both are great flyers..... Although it would have been nice to see a adjustable incidence. for the wings/elevator....
corch 09-15-2014 10:19 AM
Already moved from late sept to late oct. Hope to get one by Feb!
2M are 10S
kochj 10-03-2014 06:56 PM
The Apollo 90 GP ARF is in stock ??
Anyone pick one up?
I checked out the website, and came across a dif. manufacture.... that had some great looking Fiberglass 100cc Corsairs....
kenh3497 10-04-2014 06:54 AM
Would a YS 120 NC be enough motor to fly this airframe the way it was intended. The recommended engine is an OS 155 FS pumped, or a 120 2C.
Thanks!
Ken
learn2turn 10-04-2014 06:13 PM
I just noticed the GP120 in the Tower catalog also. It's seem to me a 5S 5000mAH sounds small for a 120 sized plane. I fly my 70 sized plane with a 5S 5000mah. I would think 120 planes fly on 8S (but I've never flown and electric that big.)
pshark101 10-04-2014 07:23 PM
They're recommending a 6S battery with their Rimfire 120 motor (pretty high kV). Static amps around 80, in flight around 72. This is about 1800 watts on the ground. Should fly ok with that power for Sportsman. If the plane weighs 10 or more pounds like they're saying, then it'll likely be a bit lacking for Intermediate or higher sequences. I would go with 8S and a lower kV motor.
drac1 10-05-2014 03:22 AM
Thanks!
Ken
I never had a YS 120 four stroke, but may be OK. If you have one lying around I would give it a go. A better option would be a DZ140 or 160. The DZ160 is smoother than the 140, but it would depend on prop clearance.
If it were me, I would go for the DZ160.
I wouldn't even consider the OS 155, YS DZ's are far superior in performance. The 140 will run rings around it, but the 160 would be a great engine for this plane.
kenh3497 10-05-2014 02:29 PM
Taking a closer look at the specs I think the YS120 would fly the plane BUT is might not be a satisfying experience. It would pull the plane through the basic loops and rolls but vertical performance would be WAY down.
Ken
drac1 10-05-2014 04:46 PM
Ken
A DZ160 will give you unlimited vertical.
corch 11-25-2014 08:03 AM
Anyone get one yet? Noticed they were in stock. Earliest I'd be able to get mine is feb 2015 :(
kochj 11-27-2014 04:42 PM
At 1st I didn't get what you meant by "DZ160" ect. I was like " is that a old brand that has been recently imported!....
I have a DZ 1.60 that I picked up used that I haven't ran yet. Thought about placing it in my Ef 78" extra, or I my topflite 1.20 corsair.
I had originally wanted to place it in the Ef 2m Vanquish but I am tired of modifying planes for my engine of choice to fit. PITA! Gets old after a while.
The .90 size pattern plane that tower now caries, (gas tank placement over C. G, and fuel line run and long tunnel) is more thought out than the sequence... The Devil is IN details and great planes has yet to change with the times, when it comes to the hardware and control links... They discontinued models, revise the "over all airframe shape" but fail to do something really flattering in terms of design.
Why not have a tank over CG placement in the Sequence?.. I realize that not all engines can do well with it there, but at least give the option.
kochj 11-27-2014 04:50 PM
All in all I do like the "main shape" of this plane. Would like to pick one up, but have too many planes right now. I would like to see a build of it! Get some picks of it !! Someone standing next to it with the nose down?
