Vanquish flies slightly nose high.
As the title says, the plane has a 2-3 degree nose high appearance at mid to high throttle. It has no elevator trim visually, and 0 degrees on the stab and +.5 degrees on the wing. C/G is such that only a modest amount of down elevator when inverted. Suggestions welcome. I'll try them tomorrow. TIA guys.
Gary |
Hi Gary, I found that 0.6 to 0.7 degrees plus wing incidence tends to be better with the Vanquish than the recommended. That's where all of mine have been set.
Sheldon |
Originally Posted by Smooth Pilot
(Post 12068687)
Sheldon Gary |
| All times are GMT -8. The time now is 10:28 PM. |
