RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   4.8 or 6V for pattern flying? (https://www.rcuniverse.com/forum/rc-pattern-flying-101/1248231-4-8-6v-pattern-flying.html)
dave_anderson 11-03-2003 10:43 AM
What are you guys/gals doing for battery power on your 60 size pattern ships? I have a Zen 90 I am refurbishing. Gonna put a YS 110 on it and I have S9202's all around. I have heard that 6V gives more crispness, is it really that noticeable?
Dave
MarkNovack 11-03-2003 10:56 AM
RE: 4.8 or 6V for pattern flying?
Dave,
With the 9202 servo, which is a good coreless servo, the 6.0 battery is very much recommended. The 9202 is a little older, less expensive, and therefore a little weaker and slower than others and the extra voltage will enhance this servo's performance noticeably. Be sure to check you rudder servo occasionally as it receives quite a bit of punishment. A new gear set every 50 flights or so on the rudder is a good way to spend $6.00.
Mark
