RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Great Planes Venus Center of Gravity? (https://www.rcuniverse.com/forum/rc-pattern-flying-101/2118631-great-planes-venus-center-gravity.html)
GarySS 08-25-2004 07:12 PM
I'm a novice when it comes to setting up Pattern plane so I have a question regarding my Venus' CG. When quickly throttling back (hands off) the plane maintains a pretty good trajectory without an abrupt drop. But when I test it inverted I have to hold quite a bit of down elevator so taking my hands off the controls is out of the question. Should I move the CG back? If so how much from the factory recommendation (this is where the CG is now).
GarySS
Schpankme 08-25-2004 07:51 PM
RE: Great Planes Venus Center of Gravity?
1 Attachment(s)
Here's a chart showing the settings, also included is the link to Great Plans Technical Data - control throws, center of gravity, etc.
[link=http://www.greatplanes.com/techsupport/technotes.html]Airplane Technical Data[/link]
_________
Schpankme
GarySS 08-26-2004 08:39 PM
Thanks! I pretty much had that info. I guess I will just move the CG back in small increments and see how it feels.
Schpankme 08-26-2004 10:04 PM
Sorry Gary, I read your subject line and responded to that.
As to your problem, I'd look at moving the CG back to about the 5-inch mark. If I remember right, this will require moving the battery to the slot behind the servo tray. After your changes try some knife-edge and inverted flight, if you’re pulling to the canopy add one to two turns of "neg" to the ailerons for trim.
_________
Schpankme
GarySS 08-27-2004 09:18 AM
Thanks, I will try that.
