RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Pattern plane and servos? (https://www.rcuniverse.com/forum/rc-pattern-flying-101/2287114-pattern-plane-servos.html)
SunShyne 10-25-2004 05:25 PM
Hi gang
I am about to start on a 90 sized Pattern plane and this will be my 2nd one ever. First was a 40 sized so it was a standard build. This one is a bit larger so im still sorting out the details on it.
My question is what servos do you guys recommend? I have 1/4 scale planes and those are easy to buy for. 40 sized I usually put in standard Futaba 3004's with good results but with this 90 size plane im in a quandry. How much torque should I opt for and do you guys have any specific servos you prefer over others? I dont intend on competing but would like good authority without having to sell my organs again!
I have a few Futaba 9202's laying around but am not sure if they are enough. In the pattern world do they make a big deal with mg versus nylon gears?
thanks!
matt [8D]
Funtana140 10-25-2004 06:18 PM
RE: Pattern plane and servos?
Go with them they would be fine. If you need to change them, which I doubt, you can always switch to Digital nylon geared servos.
blademan7065 10-26-2004 06:10 PM
The 9202's should do fine. If you are looking to get alittle bitmore out of the servos you could use tha HiTech HS-635. They are carbonite gears, 69oz" of torque and the sdpeed is good as well. I think that they come in around .18 @60*. They are pretty cheap too $35-$40 depending where you get them from.
