RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Tail Slide... (https://www.rcuniverse.com/forum/rc-pattern-flying-101/2766979-tail-slide.html)
Sukhoi_Madness 03-15-2005 06:15 AM
Tail Slide...
Can someone please explain how to do a tail slide...
Cheers
[8D]
ampa 03-15-2005 10:48 AM
RE: Tail Slide...
from straight level pull up to vertical,once your bird is perfecly vertical cut the engine the model will stop and(is mandatory) will begin to come back tail ahead still prfectly vertical now you have two choises: if you give elevator up the model will drop the nose with the landing gear dow(tail slide gear down) if you give elevator down the plane will drop the nose with the gear up(tail slide gear up), to be successfull in these maneuvre is important when you cut the engine that the model is perfectly vertical otherwise it will not come back tail ahead.
Sukhoi_Madness 03-15-2005 03:38 PM
RE: Tail Slide...
Sweet... Thanks Dude...
hillmanr2 03-19-2005 01:19 PM
RE: Tail Slide...
I'm just starting to learn basic pattern maneuvers and am looking for free drawings or video on the net of the proper way these maneuvers should look. Stuff like cobras humpty bumptys stall spins ect,
