RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Pumped engine fuel installation (https://www.rcuniverse.com/forum/rc-pattern-flying-101/2964054-pumped-engine-fuel-installation.html)
David Kyjovsky 05-11-2005 03:55 AM
Recently I was helping my friend to set up and tune his Thunder Tiger Pro 1.20 . This is a motor with integrated pump and if tuned on the bench or if the plane flies upright, the motor runs nicely (with tuned pipe). In negative G maneuvres, though, the motor quits - every single time.
Now, I suspect the problem is not in the motor itself, but rather in the fuel installation (when running, the motor does not know if it is inverted - or am I wrong?). The tank is moreless in the level of the carb. The only really non-symmetrical thing is the vent line - it goes to the top of the tank, the line exits under the plane.
Any thoughts?
David
