Wing Tube
Hi
I was just wondering what the procedure for installing a wing tube and socket is for both built up wings and also foam core iwings. I was debating wether this was the right forum to ask this question. But both models are pattern aircraft so I thought it was appropiate. The wing tubes and sockets are ppg composites carbon fiber ones. Are there any special tricks setups that help ? Thanks Troy |
RE: Wing Tube
Troy,
From where are you starting? Is there a socket in the fuselage? Is there a hole in the wing? What airplane and construction type? The level of the answer depends on the above. Ken B |
| All times are GMT -8. The time now is 09:24 PM. |
