RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Preinstalled firewall, how to mount engine (https://www.rcuniverse.com/forum/rc-pattern-flying-101/3605525-preinstalled-firewall-how-mount-engine.html)
Divesplat 11-30-2005 11:57 PM
Hey everyone.
My new plane has the firewall already installed. How do you go about mounting the motor mount to ensure thrust line, etc? I typically mount the firewall with the engine and mount taped it the engine compartment using them as a guide to set the firewall. Am a little perplexed on this other way.
Thanx in advance.
ed
NJRCFLYER2 12-01-2005 01:22 AM
RE: Preinstalled firewall, how to mount engine
The easiest method I know of is to make a temporary clamp to hold the engine & mount together so that they can be slid into alignment. You drill a hole in the center of the firewall, making sure that it is a large enough diameter to accept something like a 6-32 bolt and also has enough play to let you move things around. Then, you pass the bolt through a washer or small wood plate, whatever will let you grab the engine mount and pull it against the firewall. On the other side (inside the fuselage and behind the firewall), you will screw that bolt into a combination of a blind nut mounted on a plywood stick. That stick is big enough to grab the firewall from behind and allow you to snug up the assembly to the firewall and still move it around for alignment. Once it's all set, mark the mounting hole locations and then remove everything for drilling.
