Pattern ARC or ARF
Looking to find out who makes a good pattern arc or arf and that is currently available, something 2m size preferably fixed gear for 1.40 size engines. thanks for any info
Pattern ARC or ARF
Pattern ARC or ARF
anyone have good vs bad things about the focus arc? what engines are you running in them?
who else makes arc or arf pattern ships? |
Pattern ARC or ARF
I recently searched around for a 2 meter ARF for use with a 2 stroke engine and found precious few that weren't designed around a 4 stroke engine. The problem is the pipe tunnel, especially with an ARF - they aren't long enough to handle the 2 stroke pipe and would require modification. The Focus ARF will handle all but the Bolly 2 stroke pipes, and seems to have been pretty well thought out. I'm using a Bully 1.20 2 stroke and have been pleased with it so far.
| All times are GMT -8. The time now is 09:49 PM. |
