Hydeout pipe & header info ?
What is the header rise for a Webra 145 in a Hydeout, OR, how can I calculate what the rise should be.
Also what are some good pipes for the Webra Thanks, Paul |
RE: Hydeout pipe & header info ?
Hello everyone,
Well, I’ve been trough 3 different Tune pipes before I’ve found one that will suit me. I’ve needed a Pipe that will tune significantly shorter compared to other, because off my Pipe tunnel on my plane. This is a Focus II. And the shortest set-up that I could find was the Tune-pipe from Aero Slave. I’ve it set-up at 25 ¾ inch for the glow-plug to the first baffle. This pipe is also one off the lightest that I’ve seen. The pipe from Aero Salve is working great, and I would recommend it. I’ve also tried the ES Design 2C160L9, this is also a great pipe, but this set-up was too long. The pipe itself was a work off art, really nice done (finch) product. And also an other benefit it has compared to the Aero slave one is that it’s a whole lot quitter. Hope this helps. Regards, Danny Koolman www.arubarcclub.com |
| All times are GMT -8. The time now is 08:41 AM. |
