help ! i cant do an inverted spin
hi, how do u guys do the inverted spin menuveur? for me, i enter inverted, stall, as the plane stalls, i feed in rudder and ailerons(same directions as rudder) and at the same time hold down elevator, but i cant spin my plane, instead, it slowly spirals..... how can i solve the problem?
RE: help ! i cant do an inverted spin
Flip the direction of the ailerons.
Ailerons and Rudder should be opposite with down elevator. Just like a negative snap roll.
Arch Stafford |
With enough rudder and elevator throw, you shouldn't need aileron. Maybe a little intially in the entry.
Hi
Rudder and ailerons have to be opposite. Look at position of CG if you don't want to use ailerons ! regards |
just get the stall , and the plane should be down the nouse , then "cross" the controls(rudder-aileron).
Do as Checho says...
also consider that the true spin maneuver shall be performed without ailerons; otherwise it's considered as descending snap roll or flat spin (depending on how do you combine ailerons with rudder). Try this for inverted spin: before the wing stalls, feed rudder to the left (opposite to the engine torque). DO NOT feed aileron at all, instead feed just a little down elevator... Hope it works!!! Guille |
hi guys! thanks a lot for the info, will try them this weekend;)
| All times are GMT -8. The time now is 08:01 AM. |
