RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Pattern Plane Design Considerations (https://www.rcuniverse.com/forum/rc-pattern-flying-101/5062356-pattern-plane-design-considerations.html)
Nickolas 12-01-2006 01:07 PM
Hi,
Lately I've been trying to explore the basic concepts of pattern plane design. Can someone provide an overview of the latest trends in pattern design and the reasons why pattern planes have been designed like that?
Also how does root/tip ratio affect the pattern plane stability? I notice different ratios in well known planes that'why asking.
Looking forward to your replies,
Thanks and regards,
Nick
MHester 12-01-2006 03:28 PM
RE: Pattern Plane Design Considerations
Ahhhh what the heck. I'm going to post this with my first point being: These are MY opinions, right or wrong, and I don't have the time or energy to get into a big arguement. I would love a good debate on the matters, but if it turns nasty, I'm out. The question you ask seems like a very simple one, but reality is a lot different. So here goes.
Pattern plane design is centered around one concept: balance.
What you want is the perfect blend of neutrality in all attitudes of flight, inherent stability (EI it goes exactly where you point it in any angle of flight) and manueverability. if you design or set up a plane to be dead stable and straight, it may have trouble with snaps and spins and the like. If you set up a plane as a snapping/spinning monster, you may have to give up some of the stability around center.
Right now, something that is not discussed openly, or at least hasn't been, is that we in the US especially fly 2 entirely different types of pattern. Everything from sportsman to the FAI P sequence is what I would define as "pattern". The other type is the planes designed for the F sequence of FAI specifically. These schedules include many combined rolling/pithing/turning manuevers that the rest of the world never sees in competition. In short, a "real" pattern plane designed and optomized for the "pattern" schedules isn't necessarily the best plane for rollers and such. This is why you're seeing those silly looking T canalizers popping up. All it does is smooth the airflow from the spinning prop and direct it at the rudder/fin to neutralize some of the aerodynamic blanking that occurs with most wide body planes. If you have a large tall fuse and you throw it up on the rudder in KE flight, you wouldn't believe what that airflow is doing around the tail section. It's not pretty.
Now for the shocker.....almost all of the brand new cutting edge planes are designed specifically for the F sequence. (Duh?) But here's the catch.....a guy that can fly that huge monster on a level of the FAI Nats finals in the US has no problem dealing with what he's giving up in the P pattern. Most of these guys are so freakin good that it just doesn't matter, they don't really notice. Now take that same plane, hand it to a very accomplished intermediate pilot, and watch him fly it. in calm air he'll fall in love with it. Add a 25 mph crosswind and he'll wonder why he has his hands full. It's because he's flying a plane that was not really designed with him in mind. But since Billy Bad-***** flies it in FAI and is on the cover of all the magazines, he MUST have one because it must be the greatest plane he can get his hands on. Well it is, but not for intermediate.
So on to the design questions specifically. Let's begin with the wing.
A full 2 meter square plane with a full 2 meter wing was all the rage years back. But, people began to notice that snapping and spins were suffering a little. You had to really nail the set-up or they'd be hit and miss. Lots of zeroes. After a while people discovered that we simply had too much wing for the sequences we were flying, and that's in almost all classes. An 1100in wing is a kite. Good luck not zeroing a snap or spin here or there. if the plane was less than 10 lbs, spins breaks were really hard to get right.
Enter the new style of wing. About 4" or so total clipped from the span, and somewhere between 925-1000in of area. Less mass, less lift to break into a snap/spin, things got easier. Also the older style wings had a straight trailing edge. This made the effective sweep angle of the panels really significant. This really makes a plane roll easy, it snaps ok, but in turbulent wind it will throw your plane all over the place. So the sweep angles were lessened and the wings now carry more of a double taper. This makes the plane snap fairly easy all things being equal, and the effect of turbulence is lessened. It does make mix values increase slightly given the exact same plane otherwise.
Now add thicker wings and trailing edges. This allows the plane to fly more sbale at a slower speed, and the thicker TEs make the wing more stable, especially in turbulence. Thick TEs act like built-in expo, and this works on pretty much all surfaces.
As for the taper ratios, anything about 2:1 and you get incredible snaps but you shift the balance toward manueverability and away from stability. The design question is "how much". You'll find every school of thought out there, and they are all right (and all wrong too, depending on who you ask).
Dihedral is necessary to minimize roll coupling in KE flight. You can affect this to a large degree by where you locate your wing on a vertical plane. As in, how high the wing is on the fuse. the closer to center, the less dihedral you will need as a general rule of thumb. If you mount the wing really low you will have to use a lot of dihedral and that brings about other problems in certain conditions and attitudes. Too close to center and you're likely to get into some wierd mixing curves depending on the overall design of the plane.
Fuselage: Here's another area where things can get weird. "Wide body" fuselages are all the rage nowadays. But super duper width can really mess with the areodynamics around the tail section (see above about aerodynamic blanking). 6 1/2" is about right. Anything more and you have to get creative with the airflow. The Symphony is a good example of a really wide plane that uses curves and flutes to get the airflow right. And it's still not perfect, but it does a better job than most in that respect.
Where a large fuselage helps is in it's height. Given a conventional fuselage (with none of the T canalizers or weird strakes that Nat Penton is famous for) a fairly tall fuselage makes rolling manuevers easier, and you can perform them much slower than a skinny plane like a Prophecy for instance. Since slowness, grace and "constant speed" are the main goals of pattern flying right now, a tall fuse helps a lot and is very nice. However there is always a drawback......put that sucker in that 25mph crosswind and have fun with the most bizarre crab angles you've ever seen. Anybody that watched the Nats finals this year had a front row seat to exactly what I mean. Again, this might not be the best option for Joe Intermediate. But he'll fly it anyway....LOL
Also the genral shape of the fuse has a LOT of effect on how the plane flies. years ago drag was the key to slow flight. And I mean, big, ugly aerodynamic drag that borders on parasitic drag. Check out the old Smaragd for instance, have a look at the bulbous look of that plane. Drag city man!!!! of course in a high wind, you had to really work to make the plane penetrate and move along. That's probably not the best example of this, but since it spawned so many clones, I figured it's familiar enough to get the point across.
Now we have evolved a step further it seems. Somewhere along the way, we had another look at the japanese planes. These things were huge and sleek, but they didn't have all those abrupt cuvres and angles; the lines flow nicely....and so does the airflow. So now designers are heading back towards sleek, clean designs....just bigger.
Now for the real pickle: the tail section. This is what controls that plane in every weird axis it encounters except for the roll axis. Design here is more critical that one might think. We'll start with the stab since it's fairly straight forward. the area of the stab should be somewhere between 23-25% of the wing area. The larger the stab, the more stable the plane....and the harder it is to snap. The smaller the stab, the more agile the plane is.....and it is a little harder to lock in around neutral. So again, it comes down to balance. You have to find the right area. Also in direct relation is the moment of the center of lift of the wing to the center of lift of the stab. The longer it is, the less area you need, and the more stable it will be. the shorter it is, the larger it needs to be and it will be less stable around the pitch axis given the same design/balance/etc. Thickness is really personal choice, like the wing. A thicker stab is really kinda dead around neutral and gives a lot of drag, but get it too thick and other things suffer. Again, balance. Depends on the overall design of the plane and what you intend to do with it.
Fin/rudder: Here's the one place every one in the world is still trying to figure out. We've seen it all and it's still changing almiost daily. Small fins and rudders, large fins and rudders, HUGE rudders with counter balances, sub fins, you name it, it's being tried. Even boost tabs.
the rudder/fin is a direct relation to everything since pattern is very rudder intensive. ESPECIALLY the F sequence. Too much and it gets touchy around center but has oodles of authority. Here is where you'll find those 3/8" TEs on a rudder. And sometimes even bigger. This was unheard of by the general public until a couple years ago. Chad Northeast was the first one I remember using a rudder TE that large, but it does work well. Also remember that if you have a huge fuselage, your fin/rudder has to grow in exact porportion to that area of the fuse. If it gets too big, you have a severe kite on your hands in even the slightest of crosswinds. But that sucker will do some serious rollers!!!!! And again, not really the best choice for Joe Intermediate.
Another important consideration for the rudder is it's relative location to the wing and stab. Too much area on top and it will pitch HARD to the belly with rudder in level flight and KE. If you manage to mix it out, watch what happens with your stall turns......heh.
The trick here is to balance it with the entire plane, and I mean every single peice including the landing gear. If you don't believe landing gear affects trim and mix, fly the same plane with and without fixed gear and retracts. You WILL notice a difference on most planes.
Balancing the rudder/fin area is easily one of the most difficult part to designing a pattern plane. you can get away with something being a little "off" practically anywhere else, but it's amazing how much just a couple of square inches here and there affects how the plane behaves with pure rudder.
Construction: It still amazes me how much misinformation is out there about this subject. here's one of the most common myths in pattern: "Composite planes are lighter than wood planes". I'd need a bulldozer to move that pile of BS. Generalizations simply don't apply to what we do, especially ones that big. The TRUTH to that myth is simple....it depends on the plane and who builds it and makes it, and how it's constructed. We've seen every extreme on all sides of that issue. Totally built up wood planes, totally composite painted in the mold planes, vacuum sandwiches, wood formed composites, everything. It flat out depends on how the plane is built, period.
I'll give a couple of examples. Some poeple design and build really awesome wood planes, but they simply over build them. They use plywood where they should have used balsa, and use balsa where they should have used plywood. they use too much bracing and not the best material selection. Then they go and slap on a pound of paint. And they wonder why that plane is 11 lbs if they're lucky. This is/was how most wood planes were done in certain areas for a while, and probably how the myth got started in the first place. (Besides marketing, but I'm not even going there). Conversely with careful attention to detail and using composites in key places, and most importantly...material selection, you can fairly easily build a wood plane every bit as large as the biggest FAI planes at 9 1/2 lbs or less. I've done it myself, and am about to do it again. Although in my personal opinion I like the way my plane flies at 10 lbs better than at 9 1/2.
On the flip side of the coin is composite planes. By now I'm sure you've heard the expression "flying eggshell". Well, some are just that. Expensive ones at that. because if there is a REAL generalization, it's that a production composite plane will require much more engineering and attention to construction than a wood plane of the same design. the trick is you don't have to worry about it; it's already done for you. Follow the instructions of those very experienced and you will be just fine. Faster to the finish, too.
But realize the down side of a composite plane is that it is (generally) much more fragile). And the lighter the plane, the more fragile it is. As a general rule of course. One rough landing and that gear and half the fuse bottom is gone. And if you're lucky the tail won't whip and snap the fuse right behind the canopy.
Does this mean to avoid composite planes, or that they are inferior? Not at all. They are just so different that you can't compare them to a wood plane, and in most cases, to each other. there are really good ones and ones not so good, just ask a lot of questions.
One last note about design. And this one sums up everything in a simple package. There is no perfect plane. As long as we sue a spinning propeller, there never will be either. Designs will always flow, change and be tweaked. Because what works well today might not be as good tomorrow. Every designer in the world is still learning. We try new things. Some things work well, some don't, some are fads, some are butt ugly but fly like a dream, some are gorgeous but fly like crap, some are obscure and outfly everything....but everything out there today, yesterday and next year will benefit from trimming and some form of mixing. Anybody who tells you different is simply ill informed. That does NOT mean some designs can be flown very well with none at all, if the mixing and such are minimal enough (what we all strive for). But given time, you WILL find conditions in which something is a bit of a problem and should be addressed in some way.
There's about 10000000000000 opinions about all of this, and this is just one. I am really tempted to just hit delete and shake my head and let it go, that might be the best course of action in truth. But there is so much BS and misinformation out there, I feel sort of obligated to shed some blinding light on the darkest secrets of pattern design and construction. If you've read this far....man you must be bored!!! But take it for whatever it's worth to you. It's your money, your time, your hard work, use it/spend it/deal with it however you like. Just watch out for the hype. If a plane is touted as "perfect" and not a single defect is noted, beware.....somebody isn't telling the whole truth or simply hasn't tested it enough. There's no such thing as a "bad" pattern plane, some are just better at some things than others.
Most of all, HAVE FUN guys!!!! Fly whatever you want and ENJOY IT. Any plane can be made to do whatever you want it to if you're dedicated and determined to spend the time to make it do exactly what you need it to do. I hope that answers a few questions and I hope at least a few of you benefit from just one thing I typed today. No matter what it is.
MHester 12-01-2006 03:29 PM
Wow, Troy Newman should be proud of me!!!!! That's a long post.......
LOL
-Mike
Knight_74 12-01-2006 03:40 PM
ORIGINAL: MHester
I'm sure some would debate a few of the items mentioned. But I for one can't find any fault with your final conclusion!
Good job.
MHester 12-01-2006 03:53 PM
I hope they do debate! (And not argue or insult on a personal level as can happen sometimes). Because every last one of us, especially me, is still learning, testing, forming opinions, trying new things, and come this time next year we could see things in a totally different manner. I reserve the right to change my mind [8D]
If somebody goes through the trouble to explain something I want to read it, and see if my mind gets changed. I want what we all seek, the perfect plane and the perfect flight! It's like golf in a way.....you'll never see that perfect plane or flight, but the fun is in the pursuit of it!
-Mike
f3a05 12-01-2006 04:45 PM
I agree with almost every bit of your (Magnum+!) Opus Mr Hester!
But my (Tall FAT) Leviosa is SO much better at the rollers than my (Tall thinner) Abbra!
And, as you say,74" of wing at 14oz per side snaps much better than 76" at 16 oz.
MHester 12-01-2006 05:03 PM
ORIGINAL: f3a05
There's more to that than JUST the fuse width though, I bet. If the Leviosa is really good at rollers, it's probably a combination of things, and also HOW the width is distributed and shaped.
We could write huge books on this stuff, this is just scratching the surface.
And yep, the less mass in the tips the better for snaps and spins. if you ever feel like it do an experiment to see this clearly demonstrated: Take 2 sets of wings, identical shape-wise. Same plane. One, build normally. Fly it. On the second set of wings, honeycomb the tips and take careful steps to lighten the end of that wing as much as you can without it getting weak. Now install those wings and fly it. You'll be absolutely amazed at the difference!
-Mike
rodney tanner 12-01-2006 07:22 PM
Good post Mike. That´s why I never got with that Tempest :-)
I still find my "old" Desire just fine for the Advanced schedule.
vbortone 12-01-2006 07:53 PM
I bet that the Black Magic is very close to that perfect balance.
Vicente "Vince" Bortone
thaus 12-01-2006 07:55 PM
Mike
Thanks so much for the discourse on design. There should be a place where such valuable information could be collected.
MHester 12-01-2006 07:58 PM
Yeah, the Tempest was an attempt to put a band-aid on a shotgun wound to the skull. I had great luck with mine, and won a lot of contests with it. But I knew it was never going to be any better than it was, and then the parts disappeared....and that's why I designed the Black Magic from the ground up.
The prototype Black Magic was awesome from the word go, but an FAI finals plane it was not. Dean Funk is currently flying it in intermediate, and if he gets some practice time, watch out....because I flew it again after all of this time, and I can't say I've ever felt a plane better suited for intermediate. Ever. Imagine a Prophecy that rolled with almost no rudder.....
And here I am 2 years later, still tweaking......but really really close to exactly what I want. The V2 is a killer plane, MUCH better than a lot (if not most), but I'd go nuts if a winter went by and I didn't take it up a notch.....
And that's what all of this is about, the relentless pursuit of something better. And better. And better.......
Always learning.....
-M
MHester 12-01-2006 08:05 PM
ORIGINAL: vbortone
Some would say it is......just not for FAI F without a canaliser. So, I'm busy making a kewl one to go on them. It's been tested and it does really carve through the rollers. Without it, it sort of skids through the "S". With it, it's fine. if you don't ever fly the F sequence, you'd be hard pressed to find any real faults. It has a few mixes, but they're not high or strange. I've flown it without mix and could at the drop of a hat, I just prefer to really spend the time trimming.
I'd say it's better than most, especially for sportsman through the P sequence. That's what it was specifically designed for. But perfect? No, just really good. Good enough for certain. And some people say it does a few things better than any other plane out there right now. I'd tend to agree. So far......
-Mike
patternflyr 12-01-2006 09:19 PM
Dang Mike, I can't read that much in one sitting LOL.
Emory.
Nickolas 12-02-2006 08:55 AM
Dear Mike
Thanks for the answer and your time. It is seems that a good pattern plane is the one you have spent lots of time on to improve it via aerodynamic enhancements or mixing. According to what you wrote no plane is perfect and even if it's perfect for Mr Joe Intermediate may not be for Mr George Master. It all comes to personal preference and flying style. The questions had to do with the general rules of "thumb" being followed nowdays in pattern design.
I am really impressed by the Japanese designs I simply like the looks of them (Zeque is the most beautiful pattern plane I've ever seen), but some of these models are only available by OXAI and are very expensive. You can get some wood kits though but I do not have the time for construction, I would like to dedicate my free time on training and improve my flying skills.
I would like to get a 2x2 ship this year as bigger flies better, the most probable candidate is CompARF Integral. What do you think of it with respect to design?
Looking forward to your advice,
Thanks and regards,
Nick
MHester 12-02-2006 07:24 PM
Ok, I'll simplify.
General rules of thumb:
Long moment from wing to stab
Tall fuselage, 2 meters long
Wing span about 74 inches long with double taper and conservative sweep angle, 2:1 taper ratio, about 950 in square average, about 1/4" thick TE, slightly swept tips
Rudder/tail: Large. Very thick TE on rudder.
Fixed gear
More streamlined look overall, canopy more forward than in years past
And that's about as general as it gets ;) From there, go nuts, try everything.
As for what I think of the Integral design......ask me again in about a week...... :D I have no opinion other than from a distance it looks promising. I'm not an expert, I just share opinions for whatever they're worth here and there. I realize that the one I might see is in it's infancy so I am not inclined to be very critical....but if it is awesome, I'll say so!
-Mike
vellum2 12-02-2006 08:42 PM
Heya Mike,
As far as the lower classes go... That old Aurora carved a line as well as my Angel's Shadow and probably a little better with the gusty wind. It doesn't fit into the current design thinking at all. There are a bunch of older planes out there that are as competitive as any other new plane for nowhere near the cost of the RTF composites. The newer designs offer the agility to roll your way through the "S", etc. So for folks out there looking to be as competitive as possible in the lower classes, I'd shy away from some of the new fat-n-funky planes. They just don't lock on as well as some of the older ships. You give up some stability when you add agility. Besides, some of these planes are just plain U-G-L-Y. But everyone knows that I like the slick looking planes better anyway. :-p
The real trick is find a plane that you really like to fly and like the way it feels in your hands. When you are comfortable with your plane, you are going to fly better.
Joe W.
MHester 12-02-2006 08:52 PM
Joe I'd have to agree with 100% of what you said.
The only place I'd see a disadvantage (and this is just my personal take on it, after just climbing through all the classes with wide body style planes) would be possibly size with some of the older planes. And then only in the wind. Up until last year, intermediate had been won every year with an older style sleek plane. Boxer 60, Carerra, Prophecy....because that particular pattern requires smooth lines and tracking and round radiuses and not a whole lot else. let that wind get howling and the guy with a sleeker plane has an advantage in that class all things being equal.
At local contests sometimes the competition can be REALLY tough, and if the wind lays down, a guy who is well practiced with a larger plane seems to have an advantage in presentation.
Advanced, who knows, it's different every year. But AC won it with an Ariel last year!!!!
Tell Ryan he must bring that Aurora next weekend. He has no choice in it, he just has to and that's that :D I need to see it up close. I'll tell you all the details then.
-Mike
vellum2 12-02-2006 10:52 PM
Good grief, you do not want to see that plane up close. It's a 20' plane for sure! (You need to be 20' away for it to look good). We have all gotten so comfortable flying these larger planes for so long, many have forgotten just how well the older designs fly. I'm sure Ryan will bring it to Tangerine though... If not, we can send him home to go get it so everyone can have some fun with it. Fixed gear no less (a crime punishable by death, but when there just aren't any of these planes around anymore, we do what we must...)
See you in a week!
Joe W.
MHester 12-03-2006 10:01 AM
ORIGINAL: vellum2
Fixed gear no less
See you in a week!
Joe W.
I'll bring the rope, I assume there are strong, high branches nearby...
-Mike
checksix 12-04-2006 11:59 AM
I have a question for you gurus out there.
Considering that, excluding sportsman & intermediate sequences, pattern planes spend about as much time inverted as upright, I've always wondered why they seem to be tuned more for upright flight? Specifically I'm thinking about the typical layout:
- wing position below thrust line
- positive dihedral on main wing
- positive incidence on main wing compared to tailplane
- right thrust on motor/engine
With the exception of the first, all of these seem to be "wrong" for inverted flight. What am I missing?
--Derek
mjfrederick 12-04-2006 03:27 PM
OK, first off, let me say that was very good summation of basic aerodynamic design you gave there Mike, my hat's off to you for putting all of that down. Now, I think I have a couple of responses for checksix, feel free to correct me if I'm wrong. Most of what he seems to have asked about can be summed up in a very simple response: the airplane still has to fly. Most pattern airplane wings have fully symmetrical airfoils (or extremely close to it). Bernoulli's principles (which are the basis for airfoils) show that a fully-symmetrical airfoil will not generate lift. The only way to achieve lift therefore is to raise the angle of attack of the wing (angle of attack = angle between the airflow over the wing, and an imaginary line drawn from the leading edge to the trailing edge). Now this change in angle of attack can be achieved one of 2 main ways: having the airplane maintain a nose-high attitude, or increasing the incidence relative to the thrust line (not realtive to the tailplane). Since a nose-high airplane does not present well to the judges, and really looks like it's just hanging from the prop, the positive wing incidence is put in. The right thrust is built-in to counter the effects of what is called P-factor. This a phenomenon caused mainly by 2 things. The easiest to visualize is a the rotation of wind around the fuselage caused by the spinning propeller. This wind strikes the vertical stabilzer on the same side (left, pushing it to the right) whether or not the airplane is inverted or upright, and always causes a left yaw whether or not the aircraft is upright or inverted (just remember when you're inverted, the left yaw pushes the plane to the right when viewed from behind). This vortex is present in all modes of flight, but is more pronounced at higher PRMs (during takeoff, acceleration for vertical maneuvers). The second cause of P-Factor is the fact that when the airplane is pulling towards a more vertical attitude (through a radius), the propeller's angle of attack increases momentarily only on the downward half of the rotation, causing it to create more lift on one side (yes, your propeller is two wings rotating). Conversely the angle of attack decreases on the upward side, causing it to create less lift. This happens whether or not the airplane is inverted or upright, but unlike the vortex created by the propeller's rotation, this increased pull causes the aircraft to yaw to the left when upright, and to the right when inverted. The amount of right thrust put into most modern aircraft attempts to balance the need for it in the upright radii, and for takeoff, with the lack of it's need for inverted radii (since the two effects that cause P-Factor almost cancel each other out). If our aircraft were never flown inverted I can guarantee you would see a whole lot more right thrust to eliminate the need most people have for rudder mixing with elevator. Since I choose to fly my airplane rather than programming the radio do it, I require right rudder during any radius I fly... it's just a fact of life. Well, I hope this helps explain the last two points you asked about, checksix. As far as the dihedral and wing position, perhaps Mike can offer some insight into those, because I frankly don't really know the answers and would just be guessing.
MHester 12-04-2006 03:46 PM
Nope, that's pretty accurate.
Keep in mind what I wrote originally is a very VERY basic generalization (I hate that) of the "why" of it all. So many othert hings can be done to achieve the same results. However, if you change one thing, in general you may have to change everything else to match it.
Just as a fast and dirty example, if you were to make the general statement "a 74" wing snaps better than a 78" wing". All things being equal, true. But if the tip chord of the 78" wing is small enough, it may indeed snap better than the 74" wing. However, you might run into serious tip stall if your taper ratio gets too wild, and that opens yet another can of worms.
That's why there aren't any real books written on just this subject. There are simply too many variables.
I'm afraid right now I don't have the time I had a few days back, I'm preparing to travel to Florida for the Tangerine contest this weekend and trying to TCB and actually get a day's practice before I leave....so, I'll have to leave it at that for now...
-Mike
f3a05 12-04-2006 04:56 PM
In very basic terms(all that I understand ,really), the dihedral bit is easy.
With a low-wing design, flying upright, you'll need a little bit of dihedral to minimise(ideally to cancel out ) roll when the rudder is applied.
When the same model is flying inverted, effectively it becomes a high-winger--and then it will need a little bit of anhedral for the same effect.
In the far-off olden days,with one-piece wings and no mixers, it was common trimming practise to have a hacksaw and some 5-minute epoxy in the flight box---if it rolled against the rudder, you landed, cut a little wedge through the top of the wing centre, increased the dihedral a bit, glued it back together, and tried again....
rwlewis 12-04-2006 10:14 PM
1 Attachment(s)
Derek,
I'm no guru, but you have made a wonderful observations. Unfortunately, many of the things you list are there as tradeoffs for aesthetics, or tradition. If you toss out the aesthetics and tradition, you can eliminate many of the things you list and get much closer to an aircraft that is much more attitude independent. The caveat, is that you get an airplane that no longer fits the mold and while it may be beautiful to some, for other maybe not. The attached pictures are of a line of planes originating with the green one, The Voodoo Express. Mine is the yellow one, and the other is a smaller version flown at YS63 at 4.5 lbs...
Mine (the yellow one) has the following traits:
- Wing is on the thrustline
- No Dihedral
- No Up/Down/Left/Right thrust
The tradeoffs made in mine for upright flight are
- stab is 1/2 degree negative incidence for zero elevator input in upright flight. (Otherwise upright flight would require holding some up elevator)
- fuse area is shifted downward at the tail to provide a drag force in pitch that counteracts the negative stab incidence in knife-edge flight.
- rudder and vertical fin area are shifted upward to provide a roll force that counteracts the rolling force caused by the assymetrical fuse area distribution.
A number of folks on and off RCU have flown the Voodoo Express line of planes and should be able to attest to their neutral stability, and unique flight characteristics. Beleive it or not, the Voodoo Express's are incredibly smooth in the wind even with very light wing loading due to their high taper ratio wings and side area that is concentrated near the CG that provides very little moment for the wind forces to affect the attitude of the plane.
You can see the influence of the Voodoo Express in the Pentathlon that flyintexan has just introduced. He has tried to balance the tradition and aesthetics with many of the aerdynamic qualtities of the Voodoo Express (and payed homage to Nat Penton, the Voodoo Guru, with a tip of th ehat in the nane of tha plane). His design is a really great synergy of the two concepts and even though it is unproven on battle, I look for it to be a force to be reckoned next season in the hands of some capable pilots.
Richard
ORIGINAL: checksix
--Derek
matt13 12-05-2006 06:22 AM
Mike, I'm glad that you did not hit the delete key as it was an interesting article to read, thank you. I have an observation to share about aerofoils as there has not been a lot said in that area. A few years ago in Australia the model to have (before all the ARF's) was a local kit called the Cyclone. When I first saw one I couldn't help but notice that the aerofoil section was quite different. It's high point on the aerofoil was almost flat for about 1.5 inches, like someone spent too much time with a sanding block in one place. The owner said it was suppose to help the model retain it's original direction after a snap roll.?? This was a model that had been developed over may years by a builder as wooden models and the design was evolved and refined before the fiberglass kit was made and it enjoys a good reputation. Matt
