Installing the YS 140dz soft mount
I have a YS 140DZ "M" with the factory supplied soft mounting system. I realize this system is made for mounting on beams but How exactly is it done? Are the front nose ring and the rear mount the only flanges that get attached to the beams. The engine mounting flanges are directly in line with the front and rear mounts.
Big Mike |
soft mount
Hi Big
This mount absorbs the vibration of an engine efficiently. However, because an engine works with thrust of propeller a little in front, be careful. Throttle doesn't become max if linkage thought the above isn't given. kobayan |
| All times are GMT -8. The time now is 06:00 PM. |
