RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   thrust for showtime 90 (https://www.rcuniverse.com/forum/rc-pattern-flying-101/5624292-thrust-showtime-90-a.html)
rc pilot 03-27-2007 10:40 AM
anybody know about the thrust on this plane??? I have had to add up thrust because it climbs when I cut the throttle.I have yet to fly it since I have done this so I haope that is all it is. Any one else have this problem?? normaly arfs come with the thrust already taken care of but maybe its different if you add a engine thats not recomended I dont know????I am using the YS 110. any comments woould be appreciated
pappy35 03-27-2007 11:56 AM
RE: thrust for showtime 90
I'm using a OS120AX with factory thrust offset. No issues that I've detected so far after about 16 flights.
JVB 03-28-2007 07:24 AM
I have been flying my Showtime for over a year and have had no thrust issues. Just used the stock setup with a Webra 1.20. I did have an issue with the stab incidence. I don't know how they did it, but one half was good and the other a few degrees either up or down. Can't remember anymore.
How are things going in Lincoln? I'm over in Hastings.
John VB
rc pilot 03-28-2007 12:28 PM
things are fine here usually never hear from someone so close thanks for the input I have heard of someone else mentioning the incidence was off before too. Maybe its a cg issue I am a little tail heavy right now.
frisconick 04-02-2007 02:32 PM
I just put a post on the Mike McConville thread regarding this. I have the same problem of needing up trim to fly level. Then, it floats along when throttled back. Best I can tell, my ST has 1.4 degrees of down at the prop hub. Didn't measure it at the firewall, but will tonight. My CG is set back to 8 1/16th trying to correct this condition.
Nick
slim56 04-08-2007 12:20 PM
If you left the stock fuel tank setup in the plane, you should be looking to see if it behaves the same way at the beginning of the tank & at the end of the tank.
MMcConville 04-09-2007 04:30 PM
Its tailheavy. Move the CG forward.
