RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Is U-Can-Do 3D .60 size suitable for pattern newbie ? (https://www.rcuniverse.com/forum/rc-pattern-flying-101/6211485-u-can-do-3d-60-size-suitable-pattern-newbie.html)
gumush 08-08-2007 08:44 AM
LCHelilover 08-08-2007 08:49 AM
RE: Is U-Can-Do 3D .60 size suitable for pattern newbie ?
It should be fine for Sportsman pattern if you set it up properly...that is basically cut the throw rates down so that is will fly SMOOTH. You don't need "3D" rates to fly the sportsman maneuvers and too much "maneuverability" will hurt you rather than help you.
G
grcourtney 08-08-2007 09:07 AM
I have seen them flown in sportsman the only drawback is high wind they don't handle it well.
gary
geh3 08-08-2007 09:12 AM
Also do not fly fast and do tight turns... that can fold the wing
majortom-RCU 08-08-2007 06:26 PM
If it's the only plane you have, then yes, it's better than nothing. The UCD is a great 3D model, and if you like flying it, then do as suggested and reduce the throws on elevators and ailerons to not more than 12 to 15 degrees. Preferably you would do this mechanically, using the shortest available servo arm length and longest available control horn length. That will smooth everything out real nice, and pattern is all about smooth maneuvers. Once you find you're doing the maneuvers well and practicing the current schedule routinely, you can then decide on putting together a plane that's designed for pattern specifically (or at least a hybrid design, of which there are some nice ones available).
gumush 08-12-2007 04:46 AM
Thanx for all toughts.
I' have ucd60 , with no engine. I'll plan to buy 91fx or 120AX.
Could you prefer other setup for Precision Aerobatics startup ?
RC_Pattern_Flyer 08-12-2007 10:26 AM
I would try and find a Venus 60 or something equivalent if you can. I competed with the 40 size u can do and won 3 contests with it in sportsman.
I have seen some rebuild the rudder to lok more like the cermark javelin with good results.
Main thing is, have fun with precision it is really a challenge.
Chuck
