Extreme Flight Vanquish P07 video
1 Attachment(s)
This video was sent to me by a young flier from Lithuania named Donatas. It is of the P07 sequence, which Donatas won at this particular contest flying the Vanquish against 2 meter aircraft.
http://www.pauzuolis-rc.com/Videos/E...Patt_small.wmv |
RE: Extreme Flight Vanquish P07 video
Having flown this little plane myself, let me tell you guys...this one is THE best flying small electric pattern type plane out there! I kept thinking "man this flies like my 2 meter"!
Everything the Brio 10 SHOULD have been, this plane IS. It flies really clean, light, and powerful. No problem whatsoever doing the masters sequence with it, or P-07 for that matter. Never had the chance to play with the F sequence though. I'll put it this way: now that things have calmed down a little for me, I'm getting 2 [8D] -Mike |
What are guys using for an F3A power setup in these. Budgets a little tight but would like to try an A123 set up in one of these.
The power set up it comes with is pretty darned good, but I would use a 4S 2200 pack or thereabouts.....
-Mike |
This is one Fantastic airplane. Chris and the team at Extreme Flight has done a fantastic job with this one. I highly recommend one for a practice airplane, and it does fly like a 2 meter locking on very well.
Great if you travel on business by car for practice sessions at small fields after work:D Chris you hit the mark again. Great job and thanks for the video. Bryan Team Kennedy |
| All times are GMT -8. The time now is 10:37 PM. |
