cuban 8
Cuban 8, does it start at the bottom half loop 45 then roll? or 45 roll pull?
RE: cuban 8
Not sure exactly what you're asking but all maneuvers start and end with a straight horizontal line. So the Cuban 8 starts with the straight line entry.
RE: cuban 8
ORIGINAL: Madflyer2 Cuban 8, does it start at the bottom half loop 45 then roll? or 45 roll pull? |
RE: cuban 8
1 Attachment(s)
This is it !
RE: cuban 8
RE: cuban 8
Very helpful link Rune.
Thank you |
RE: cuban 8
The one you decribed is the reverse cuban eight, starts in the middle, the cuban 8 star at the end with the loop then dive 45 in to a roll.
RE: cuban 8
ORIGINAL: cmoulder ORIGINAL: Madflyer2 Cuban 8, does it start at the bottom half loop 45 then roll? or 45 roll pull? Stavros ribbon drawing seems to show the half rolls before the diagonal intersects and that's misleading. Otherwise the sketch is very helpful. The half rolls must occur at the ceter of the diagonal lines as Bob wrote. The rolls must intersect at knife edge on center. For a complete list of downgrades go to the NSRCA website, under Judging or maneuvers, and look it up regards, MattK |
RE: cuban 8
Roy right its not a reversed Cuban 8!
but i think rest is right! |
RE: cuban 8
If it starts with a 45deg climb/dive then roll is a reverse Cuban eight, if it start with the loop is a Cuban 8, I guess I read it wrog on the first post.
RE: cuban 8
Hi
I lokked on FAI web ..could not find a updated sportingcode (p09 - f09). but I'm alsmost sure its a cuban 8 not a rev.cuban 8 ... Found this on a website . Take off sequence (Not judge not score) 1) Double immelman, 2/4point first, full roll second, exit inverted.(K4) 2) Half reverse cuban 8, two 1/2 rolls in opposite direction inverted entry.(K3) 3) Three horizontal rolls in opposite direction.(K4) 4) Stole turn, 2/4 point roll up, 1/2 roll down.(K3) 5) Top hat, 4/8 point roll over top, exit inverted.(K4) 6) Half outside loop, inverted entry.(K1) 7) Triangle loop, with 1/2 rolls in each leg exit inverted.(k4) 8) Figure 9, two 1/2 rolls in opposite direction on down-line, inverted entry.(K3) 9) Stole turn, 3/4 roll up, 1・1/4 snap roll down.(K5) 10) Pull push push humpty bump, 1/2 rolls up and down, exit inverted.(K3) 11) Reverse 4 point roll, (2/4 point in one direction, 2/4 point opposite) inverted entry and exit.(K4) 12) Half square loop, full roll up, inverted entry.(K2) 13) Two outside loops from top, full integrated roll over top 90°of second loop.(K5) 14) Two turn spin, exit inverted.(K3) 15) Cuban 8, 4/8 point roll and full roll in 45°down line.(K4) 16) Half Square loop on corner, 1/2 rolls 45°up line, exit inverted(K3) 17) 45°down with negative snap roll, 1/2 roll on exit.(K5) Landing seaquence (Not judge not score) Total K60 |
RE: cuban 8
1 Attachment(s)
RE: cuban 8
ORIGINAL: MTK ORIGINAL: cmoulder ORIGINAL: Madflyer2 Cuban 8, does it start at the bottom half loop 45 then roll? or 45 roll pull? Stavros ribbon drawing seems to show the half rolls before the diagonal intersects and that's misleading. Otherwise the sketch is very helpful. The half rolls must occur at the ceter of the diagonal lines as Bob wrote. The rolls must intersect at knife edge on center. For a complete list of downgrades go to the NSRCA website, under Judging or maneuvers, and look it up regards, MattK |
| All times are GMT -8. The time now is 03:15 PM. |
