Rookie question "Propellers"
I have been flying some pattern during the last months. All of the planes where from 45 to 60 with "standard" pitch propellers, but I have always wondered why the pattern propellers have such a high pitch. Whats the reason? Because I thing (guessing here) that for pattern slower is better as you have more time to correct.
Someone could help? Ramon Suarez |
Pure efficiency
Hi Ramon,
The higher pitch propellor allows the airplane to travel at reasonable and constant speed while the motor turns a comparatively slow RPM, greatly reducing noise and increasing efficiency. Modern generation motors in the 23cc class are optimized to turn, on an average, 8000rpm. To achieve proper speed on the upline at this RPM, the propellor needs more pitch. The large diameter, when idled down, especially by the YS 4-stroke motor, conversly creates a large disk that creates a wonderful brake when on the downline. Where a low pitched prop provides wonderful pulling power at slow speed, the upline speed of the airplane would be ungainly slow with a 8 or 10 pitch propellor turning only 8000. Finding the correct propellor for a given airframe, motor, weight combination is more of an art and personal preference than an exact science, but recommendations from people flying particular combinations can get one really close if not right on. Once the perfect propellor is found, it may need a complete change to deal with different wind conditions (for me, more pitch in higher winds), fuel changes, and significant changes in barometric pressure can also create a desire to change pitch by .5". That said, I know plenty of pilots who fly one prop in all conditions and fly just superbly. OK, that's my plain language explaination. I'm sure somebody here can dazzle you with brilliant lessons of prop efficiency and, as always, I would love to hear from some of the more experienced pilots. Mark |
Thanks Mark
Very good explanation, so for two stroke engines (45 to 90) the pitch would be "conventional" (6 to 8 or so)
Thanks again. Ramon |
Whatever happened to adjustable pitch propellers? I remember when I was flying over a decade ago, there was a lot of talk about pitch props, how one could use it to engine-brake, etc., etc. I was looking over the old Futaba 8SGAP manual, and it showed a diagram for a pitch prop. But I haven't heard anything about these things lately ... do people no longer use them?
I beleive it was the complication factor, and the expense...
MK marketed them in the early 80's and in fact, Hanno Prettner won the 1980 world champs with a magic fitted with an MK constant speed prop... the complication was having a 60 sized aeroplane with all this gear jammed in it... 1.ailerons 2.elevators 3.rudder 4. throttle 5. gear 6. flaps (snap flaps or speed brakes) 7. in flight mix 8. prop pitch. the fuselages were crammed with stuff and weighing in at 9 and 10 pounds, these babies were guided missiles... |
| All times are GMT -8. The time now is 08:42 AM. |
