RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   CG Obsession - Pattern Control Throws (https://www.rcuniverse.com/forum/rc-pattern-flying-101/7094285-cg-obsession-pattern-control-throws.html)
RCPAUL 02-18-2008 08:39 AM
I know of the other threads on the CG Obsession. Can someone give me starting throws on the control surfaces for using this ship in pattern?
Paul
vbortone 02-18-2008 04:41 PM
RE: CG Obsession - Pattern Control Throws
Paul,
I don't have this particular plane. I use the following procedure. This values depends heavily on the class you are flying. The concept is to use is to use the less possible throws and still able to do all the schedule if you objective is to fly pattern only. I usually start with 10-12 degrees elevators and aileron. Rudder 30-35 degrees. I suggest that you read the following tip:
http://www.centralhobbies.com/instru...s1/link03.html
Good luck,
VB
RCPAUL 02-18-2008 07:17 PM
Thanks for the Info.
Paul
