spektrum "throttle kill swithc"
Those with Spektrum radios, any suggestions or protocols used to set up a for a throttle kill switch on the spektrum radios??
john |
RE: spektrum "throttle kill swithc"
1 Attachment(s)
I have the same question for the JR 9303 2.4 Ghz radio. I can't beleive a radio at this level doesn't have a throttle kill function (or for that matter digital trims on the throttle)
On 9303 you need to use mix ,use any switch you want to use as master & throtle as slave
can you be more specific on how this is set up. I have a Spektrum DX-7.
john |
Err, the new 9303 2.4 (or as it's known here in australia, the DSX9) DOES have the throttle cut function
Make a mix THR-THR and that's it, just make to one side with the off set above idle.
Thanks guys. I reviewed the manual again. The 9303 manual does describe an idle-up mix which can easily be modified to throttle kill. I stand corrected.
Glen NSRCA 3017 |
| All times are GMT -8. The time now is 04:11 AM. |
