RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   LEO CONTROL THROWS SETTINGS (https://www.rcuniverse.com/forum/rc-pattern-flying-101/7967866-leo-control-throws-settings.html)
Captin1 09-18-2008 05:57 PM
I just got my Leo FAI aircraft , it is nice
starting to put gear in it
what lo rate settings should I use 20 or 25
for high rate go 45
thanks
petec 09-18-2008 07:26 PM
RE: LEO CONTROL THROWS SETTINGS
Which surface?
I start at 12 degrees for aileron and elevator on low rates so I know I can switch to high rates if it isn't enough. Rudder I usually set to all I can get on high rates and cut my low rates to 70%. As you fly it you will settle in on throws that you like.
What does the manual say as a starting point?
Captin1 09-18-2008 07:55 PM
Okay that sounds like a good starting place for the ailerons
what is a good number for the elevator or should I use the same starting number
the drawing does not show any numbers for movement of the control surfaces
there is no manual with this plane
petec 09-18-2008 10:07 PM
Yep 12 for both. Once you get it flyable go to the NSRCA site and down load a trimming chart so you can get it dialed in.
