Temptation canopy
1 Attachment(s)
Hi,
I was given a partially complete scratch built Temptation. It has no canopy. Does anyone know where I can get a canopy? thanks John |
RE: Temptation canopy
Maybe try Dave Guerin, of Piedmont Models. I'm not sure how well it would fit, given that the airplane you have is significantly different from the Temptation they produced, however I'm sure something could be worked out. As an aside, the airplane looks really nice.
Dave's telephone number is 336.538.0440. Good luck! |
I have just replaced my broken Canopy by bottle canopy.... it was impossible to find something similar to the original canopy
but i will keep looking. |
Thanks. Can anyone point me to some threads on building a canopy?
The canopy from a Focus II might work, but not real sure
Are you sure thats a temptation, I thought it had plug in wings
ORIGINAL: jg95762 Thanks. Can anyone point me to some threads on building a canopy? Anyway, building your own from scratch is simple.....First carve a foam piece to fit the space. Sand it to a nice contour and make it ready to sheet with balsa. For a canopy, use 1/32" or 1/16" soft sheet, well wetted to allow easy bending, and then wrap it over the canopy. Take an ACE bandage and wrap it around the work firmly and let it dry for a couple days. After it dries, trim the balsa and glue it in place with some polyurethane glue. Don't go crazy on the glue.....just a dozen dots to hold it securely. You can glass and finish in paint, or monokote it. I have done many canopies this way. Also cowls....it really is that simple Good Luck MattK |
| All times are GMT -8. The time now is 01:34 PM. |
