RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   2/3/4 Bladed Props (https://www.rcuniverse.com/forum/rc-pattern-flying-101/838416-2-3-4-bladed-props.html)
Multiplex 06-06-2003 01:50 PM
2/3/4 Bladed Props
HI GUYS, JUST WONDERING WHAT YOUR VIEWS ARE ON DIFFERENT 2/3/4 BLADED apc PROPS. WHAT CHANGES DO YOU FEEL THESE PROPS HAVE ON MODELS ETC..............WHAT DIFFERENT DIAMETERS PITCH ECT........ PROPS DO YOU USE AND WHY?
LOOK FORWARD TO HEARING YOUR REPLIES
Jeff-RCU 06-06-2003 03:47 PM
2/3/4 Bladed Props
I've been flying a 15.5x12 four blade on a muffled os1.40 with good results. The power transition is smoother than when I was using a 16-13 two blade (seems to react slower). Plus it looks cool on my Jupiter. Down lines are slower also.
krayzc-RCU 06-07-2003 01:54 AM
2/3/4 Bladed Props
3 blades pull more to the left require more or a touch of r-rudder on up lines, snap tighter, faster downlines, quiter some times depending on muffer set up (cans and its on). Better ground clearance.
2 blades the opposite of my above:
