Arcallys
Arcallys (Arcallys its a mountain that i climb with mi bicycle in ANDORRA-SPAIN) is a F3A plane that i designed en build from zero
engine its a OS 160 FX en inside the fuselage its from carbon fiber also the the cockpit ,enginecowl and wheelpants see for pictures and greetings from belgium; http://www.modelbouwforum.nl/forums/...-arcallys.html plane ready; http://www.modelbouwforum.nl/forums/...ijk-klaar.html http://www.modelbouwforum.nl/forums/...-dscf1945a.jpg |
RE: Arcallys
Very good job. It should be admired as a full handmade plane. If you want I can prepare a plan of a Japanese F3A plane. I hope you refer it and make another good plane.</p> sarashina</p> |
RE: Arcallys
| All times are GMT -8. The time now is 10:49 AM. |
