OS 140RX Need Help
<div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">I’m trying to get a plane going to make the Quincy, OH contest next weekend…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">When running at idle or the engine isn’t running, fuel leaks out of the carb. I can get it started, but loads up in about ten seconds and bogs down and dies when increasing the throttle…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">If I pinch the fuel line, it leans out and recovers. As long as I stay near full throttle it’s fine…When at half throttle and lower it will bog down….</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">HS needle is at about 1-3/4 out leanedit was aboutabout 2 turns out before I leaned it a bit. I don’t know the pump settings. Tank sits on the cross brace under the canopy above the wing tube in a Temptation.</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">This is a used engine already installed in a plane…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">Is it just a matter of the pump pressure being too high or do I have other problems to deal with…???</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">Larry Diamond</span></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">NSRCA 3083</span></font></div></div>
RE: OS 140RX Need Help
make sure the main bearing is silky smooth...... rough or unreliable idle is often the main bearing going out.
Can you reset the idle via the idle adjustment screw. It is pretty sensitive but it usually is set just to the right of center of the total throw. Woodie |
<div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">When I get it lean by pinching the fuel tube it will transition ok until it loads up again…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">Is this consistent with the main bearing? I have a set of bearings to install if needed…Would rather not, unless this is the cause…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">Larry</span></font></div>
Hi Larry,
Don't Touch The Pump! You'll never get it right again. The instruction say not to touch it. Did you lean the bottom end? I have one of these and will see you at Quincy. Not really sure what the problem is but the people in the know say never touch the pump. If you need help, Verne Kesster will be there along with Dennis Bodary. These guys are really experienced with this motor and wll be glad to help. I can be reached tonight at work at 1-800-1856-1856EX8096. Call if you like. RC11 Rick Cilles See you at Quincy in what class? |
I am assuming this engine has sat for a while since running.
Try injecting some straight methanol into the pump line. Just in case the pump is gummed up from congealed oil. Doesn't matter on the methanol even denatured alchohol will work. Not sure what type of plug you have. Either a OS F type/YS 4-stroke plug work equally well. I have not had any luck with the A5 that comes standard with it. Do not take the pump off the backplate. Bad @%$# happens as that opens up the pump just leave it on the backplate. |
I have not done anything other than adjust the HS needle...
I'll try replacing the main bearing... Dennis, Im caught between getting this going and/or trying to get the Titan airborne. If I get the Titan going and you want the plane, I may wish to use the Titan until I get the Temptation sorted out... Thanks for the help... I'll try to replace the main beiring and see wear it goes...Is fuel leaking out of the carb a normal thing? Larry... |
ORIGINAL: RC11 RC11 Rick Cilles See you at Quincy in what class? LOL Larry... PS...So if I show up with a dead plane, you feel we can get it going to make it worth the trip...? 5 hour drive...We'll get there late Friday night, early Sat morning.... |
Normally the carb will not leak fuel. like i said earlier try injecting alchohal into the pump line first.
Go ahead with flying the Titan it does'nt matter to me, as i may or may not want it anyways. Are you going to be replacing the bearing with a stock bearing or the orange sealed bearing? |
I believe I only have the OS bearing NIP...
That may get me through the day... Turning a 4 blade 15 x 12 or 11...I'll neeed to look for sure ... I will try to replace it tonight...Any tips? Never had this engine before... Larry |
doesn't the carb have a low speed idle adjustment?
Well the stock OS# is 46030008
The CFI bearing # is 29430010 This is the one you want if at all possible. If you are using the unsealed one it will work just won't last any where near as long. As far as changing the bearing it is the same as replacing any typical OS bearing. The one big difference is the piston ring. it has to be lined up with the pin in the ring groove otherwise the ring will not compress enough to put the sleeve over the piston. Leave the hammer in the toolbox. if you have it lined up correct the sleeve will smoothly go over it. It's a PIA but after two minutes you should have it. As far as the needle valve go on Tower's website Look for the parts for the OS140RX and they show the two different needles. should be able to tell which one you have by the pictures. One other thing the key for the prop washer only goes in one way the flat side to the engine. |
ORIGINAL: tschuy doesn't the carb have a low speed idle adjustment? |
Rick,
Verne wont be there, he will be either on his way, or in Portugal for the worlds. Larry, The other thing worth trying it find a setting that it will run at and just let it run for as long as you can. It might just need time. It might have gunk the pump or whatever. Also, lean the low end some, but it might just need run. The diaphram might be stiff and just needs sometime, Arch |
ORIGINAL: d_bodary Well the stock OS# is 46030008 The CFI bearing # is 29430010 This is the one you want if at all possible. If you are using the unsealed one it will work just won't last any where near as long. As far as changing the bearing it is the same as replacing any typical OS bearing. The one big difference is the piston ring. it has to be lined up with the pin in the ring groove otherwise the ring will not compress enough to put the sleeve over the piston. Leave the hammer in the toolbox. if you have it lined up correct the sleeve will smoothly go over it. It's a PIA but after two minutes you should have it. As far as the needle valve go on Tower's website Look for the parts for the OS140RX and they show the two different needles. should be able to tell which one you have by the pictures. One other thing the key for the prop washer only goes in one way the flat side to the engine. Larry</span></div> |
Thanks Arch...I pushed some Denatured Alcohol through the pump and it seemed to clear that up quite a bit...If I let it sit it will drip a little now and not at all at idle. So that seems to be under control...
Now it idles very well and I can adjust top end. I'm getting about 7,900 on a 4 bladed prop 15.5x12 APC w/ PM Mean Green (15% w/ 18% all synthetic oil). However, once it idles for any length of time or even 1/2 throttle, it will bog down and quite as soon as I start to advance the throttle. If I pinch the fuel tube it will pick up and run. If I go high then low and back to high throttle without too much delay it transitions well. If I'm at idle for about the same time as stall turn down line (2 or 3 seconds) it will bog down... This is what I'm assuming everyone has keyed in on as the symptom of a main bearing going bad... Off to surgery...now I get to see what the inside of a 140RX looks like... Again, Thanks for all the help.... |
The bearings play a big part with the RX.
I have adjusted the pump on mine years ago. Ran much better, seriously helped the mid range madness that accompanied many a RX. Mine was so rich is was spitting globs of fuel out of the card whist running in the mid range! I read about the cure in Don Lowes RCM column a decade or so ago. He'd received an article from Australia and published it in his column. Worked great. |
<div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">First I want to thank Jeff Hughes. He and Steve Maxwell were the two that helped me get started in pattern in 2003. Jeff spent about an hour total with me on the phone talking me through the main bearing replacement.</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">The engine is running strong. I replaced the front bearing, rear bearing, and piston ring (Dennis told me how to do it right) because I didn’t follow proper directions.</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">Idle’s reliably for over a minute at 2,000 RPM…No Hesitation transitioning to full throttle and no spitting fuel out of the carb at all…</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">I did not need to mess with the LE needle. So the solution to this was…</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">1) Purge the pump with denatured alcohol. I used about 5 ounces…</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">2) Replaced the main bearing…</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">Thanks a toon for everyone’s input…</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">Larry</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">PS…Hope to see ya at Quincy next weekend for those attending. You may want to bring hard hats while you judge my flights…vbg</span></div>
Final update...
<div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">Got to the flying field and charged everything up…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">Started the 140RX and tons of power running very smooth. Lisa took the Temptation out to the runway, one more run up to clear the engine…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">Take off was beautiful, very smooth at ½ throttle and very nice climb out to about 20’ and bank to the left for a easy 180 degree turn down wind…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">Leveled wings and was about 100’ and added power…No power, now a glider….it was a tight rope staying just above stall to land easy in the tall weeds…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">I observed the tip stall about 2 feet above earth, and yep it’s a composite fuse…you know where it folded. That was the only damage…Repairable to some, not sure I want the task…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">I have no idea why the engine quit and will probably never know at this point…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">As for my weekend, this was the second plane in two days that were sacrificed to the RC Plane Gods if you will…Lisa’s trainer met it’s demise yesterday while my dad was on the buddy box. He got into trouble and I took back control at about 50’ with no problem. Well until I pulled elevator to gain altitude. I observed a narrow blue covering that I couldn’t place right before she headed to earth at full throttle. My thumbs were in the low left corner on the right stick and full up on the left stick. I held it in that position to verify what happened…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">The blue line was the only blue on the plane…The leading edge of the wing. Normally not a bad observation if the plane is coming toward you, however, it was going away from me. The wing left the plane when I pulled elevator…The wing first lifted on the left appearing to bank sharp to the right…What I saw verified my final stick positions…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">I’ve only lost one other plane since 85’…I guess we all pay up sometime or another…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">Not sure what I will do from here, but we will not be making Quincy, OH…</span></font></div><div><font color="#000080" size="2"></font></div><div><font color="#000080" size="2"><span style="color: navy; font-size: 10pt">Larry Diamond</span></font></div> |
| All times are GMT -8. The time now is 01:21 PM. |
