RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Looking for current Pattern Sequences from other countries (https://www.rcuniverse.com/forum/rc-pattern-flying-101/939194-looking-current-pattern-sequences-other-countries.html)
PatternFlyer 07-09-2003 03:34 AM
I just got bored and was reading old Japanese magazine with a pattern sequences.
Here in the US, we are using AMA sequences + FAI.
If you are from other countries, would you post the sequences of each classes?
Thank you,
robert 07-09-2003 07:43 AM
www.maci.ie (look at the documentation)
PatternFlyer 07-09-2003 08:40 AM
Robert,
So, for Novice class you choose 9 manuevers out of the 23?
How many classes do Ireland actually use?
I only see Masters and novice.
Very interesting.
jeffmill 07-09-2003 09:57 AM
Zimbabwe pattern
Hi Patternflyer
In Zimbabwe we fly 4 different classes. Novice, Intermediatte, Expert and FAI
Here are the various schedules for the 1st 3 disciplines. The FAI is obviously the international P03/F03 until December when it change to P05 and F05.
Novice
1 Take off sequence
2 Two Inside Loops
3 Two horizontal rolls
4 Square inside loop
5 Cuban 8
6 Stall turn with 1/4 rolls
7 45 degree down 1/2 roll on centre (inv entry)
8 Double immelman
9 Straight inverted flight
10 Reverse outside loop, 1/2 roll entry & exit
11 Two opposite rolls
12 Landing approach, rectangular
13 Landing
All manoeuvres are centred, there are no turnarounds to perform.
Intermediatte
1 Take off sequence
2 Top hat with 1/2 rolls
3 Stall turn, full roll up
4 Three horizontal rolls
5 Immelmann turn
6 Two outside loops
7 Half square loop, 1/2 roll down
8 Triangle rolling loop, full roll over top
9 Humpty bump with rolls, pilot's option
10 Vertical 2/4 point roll up, exit inverted
11 Half loop
12 Two of 2 point roll, same direction
13 Half square loop, 1/2 roll up
14 Two turn spin
15 Half reverse cuban eight
16 Double immelmann
17 Landing approach, rectangular
18 Landing
Expert
1 Take off sequence
2 Reverse cuban eight
3 Humpty bump, 1/2 roll up(pull for 1/2 loop over top)
4 Four point roll
5 Stall turn, 2/4 point roll up, 1/2 roll down
6 Square loop with four 1/2 rolls
7 Top hat with 1/4 rolls (flat top inverted)
8 Square loop on corner
9 Immelmann turn
10 45 deg down, full positive snap roll
11 Half cuban eight, 2/4 point roll down
12 Two loops with two 1/2 rolls
13 Half square loop, full roll up
14 Inverted three turn spin, exit inverted
15 Humpty bump with rolls, pilots option
16 Two of 2-point roll, opposite direction.
17 Stall turn, full roll up
18 Double immelmann, full rolls
19 Landing
Hope you find something you can use.
regards
Jeff
Imac Kiwi 07-09-2003 10:08 AM
Pattern Schedules
Here are the New Zealand schedules
F3A is now PO5
Greetings from dowmunder NZhttp://www.nzmaa.org.nz/rules/dec200...%20Dec2001.pdf
Scorpio 07-09-2003 12:08 PM
Irish pattern classes
Pattern flyer,
In Ireland novice is a fixed turnaround schedule, the schedule you saw was an old one. We fly three classes, Novice, Masters and F3A. At present we have around 12-15 pilots in F3A, 5-6 in Masters and only 1-2 in Novice. Most of the pilots have progressed through the classes and that is why F3A is larger than the other classes
MACI NOVICE CLASS
NO MANOEUVRE K FACTOR
1. Take off and downwind pass 1
2. Procedure turn upwind 2
3. Stall from level flight upwind 2
4. Straight and level flight downwind 1
5. Half reverse Cuban eight upwind 3
6. Immelman turn downwind 3
7. One loop upwind 3
8. Single horizontal roll downwind 3
9. Split ‘S’ upwind 2
10. Rectangular approach and overshoot 3
11. Landing 1
MACI R/C MASTERS AEROBATICS CLASS
1. FAI TAKE OFF SEQUENCE 1
2. TRIANGLE LOOP 3
3. HALF REVERSE CUBAN EIGHT, FULL ROLL 3
4. HALF ROLL INVERTED TO UPRIGHT 2
5. HALF LOOP 1
6. SQUARE LOOP 4
7. HALF SQUARE LOOP 2
8. SLOW ROLL 4
9. HALF CUBAN EIGHT 2
10. FIGURE ‘Z’, HALF ROLL UP 4
11. FIGURE ‘9’, PUSH 3/4 LOOP, VERTICAL
DOWN PULL OUT 3
12. KNIFE EDGE (3 SECONDS) 4
13. IMMELMAN TURN 2
14. 45 DEGREE DOWN WITH FULL ROLL 3
15. PULL, PUSH, PUSH HUMPTY BUMP,
INVERTED EXIT 2
16. 2 OF 4 POINT ROLL INVERTED TO UPRIGHT 3
17. HALF SQUARE LOOP 2
18. REVERSE COBRA, HALF ROLL DOWN/UP 4
19. TWO TURN INVERTED SPIN 3
20. 45 DEGREE UP, TWO ROLLS 4
21. HALF SQUARE LOOP, HALF ROLL DOWN 3
22. HUMPTY BUMP 2 OF 4 UP, HALDF ROLL DOWN 5
23. FAI LANDING SEQUENCE 1
TOTAL K FACTOR 70
F3A- As FAI PO3
Hope this helps
Jon Wold 07-09-2003 12:27 PM
Norweigan and Nordic schedules:
http://home.online.no/~ofremmi/F3A/S.../Schedules.htm
Sprink 07-09-2003 02:31 PM
Link for UK schedules:
http://www.spinmail.com/gbrcaa/schedule.htm
Pattern is not really my thing, but pop in here as you guys do post some good tips. Glad to be able to give something back. :)
jlejarza 07-09-2003 08:04 PM
In spain:
www.sportec.com/fae/aeromodelismo
PatternFlyer 07-09-2003 10:41 PM
My sincere thanks to all who responded so far.
Exciting combinations of sequences!!
I am still trying to find where those sequences are for the Spain :D.
it's fun to look at all those sequences.
Anyone from Asia? I am from Korea, but am still searching for the Korean sequences.
Keep them coming~~
mc71 07-09-2003 11:19 PM
Here is a link to the australian pattern site, we are trying to get the manouvers in the sportsman schedule that have verticals changed so that more people with less capable aircraft can still have a go at competitions.
http://www.australianpatternassociat...au/index2.html
jlejarza 07-10-2003 04:23 PM
Sorry,
the correct link is: http://www.sportec.com/www/fae/aerom...F3A_b_2004.pdf
This is the intermediate schedule
