RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Need more help on my Tiporare (https://www.rcuniverse.com/forum/rc-pattern-flying-101/956330-need-more-help-my-tiporare.html)
flatspin17 07-14-2003 03:47 PM
I want to thank Tipo750 for the help the other day.I need to know how wide to make the ailerons,elevators and rudder on the Tiporare I'm building I have no plans and I hate to guess wrong.
JWN 07-14-2003 03:52 PM
The rudder is made buy gluing two 1/4" sheets of balsa together and sanding the taper in to it.
Ailerons and elevators are cut from the surface and capped with 1/4" balsa then sanded flush with the surface. Be sure to remove 1/4" foam from the surface to allow for the facing you are gluing on.
John
MrSteve09 07-15-2003 03:15 AM
Tiporare Size Surfaces
Dear Flatspin,...
I am not sure which version or size Tiporare you are building. But I have the plans for the orignial Tipo that Dick Hanson published in the February '80 issue of Model Builder magazine.
If the size/location of these control surfaces would be of any use to you, I would be more than happy to pull the plans out and give you detailed dimensions.
Please let me know if I can help.
Sincerely,
MrSteve09
tipo750 07-15-2003 04:51 AM
There were different versions, but I'll assume when you say "Tiporare" you are referring to the original. The ailerons were 1-1/2" x 1/4" trailing edge stock which was also the trailing edge itself. Everything else is shaped according to the plans, and you might want Steve's help on those figures.
