source for Carbon Fiber gear and wing tubes?
I don't know if this is the place to ask this but if not I could find it. So where can I get these?
thanks |
RE: source for Carbon Fiber gear and wing tubes?
f3aunlimited.com has Graphtech gear and PBG tubes
Tom M |
thanks
Chris Moon is a good guy but if he doesn't have what you are looking for check these out.
Wing tubes....troybuiltmodels.com Landing gear....aeroproduct.net |
Yeah, Randy Smith at Aeroproducts has Bolly gears. Just got mine today.;)
Jerry Budd has PBG wing tubes
http://www.buddengineering.com/Merch...ategory_Code=P Here's a link to Graphtech http://www.graphtechrcshop.com/main....3.qscstrfrnt01 |
thanks Ron, I found Budd on the NSRCA links
I have one that is 22mm (.866, or almost 7/8") x 23" long w/ fiberglass sleeve. PM me if you are interested.
The guys at Graphtech are pretty cool. I'm happy with the custom/modified set of gear I got from them and will use them again in the future.
thank's ya'll for the help
Troy built has the size tubes we use for around 30$. No sleeves
MattK |
I just received a wing tube from TBM yesterday. It is seriously UNDERSIZE on the O.D., which is very frustrating for me since I went to great lengths with TBM to get one that was slightly oversize. So I will probably not use TBM again for wing tubes. Just my experience.
I was told I'm going to need 7/8" X 30", I'm going to go carbon fiber on the tube, is the sleeve c.f. also?
ORIGINAL: Gungadin I just received a wing tube from TBM yesterday. It is seriously UNDERSIZE on the O.D., which is very frustrating for me since I went to great lengths with TBM to get one that was slightly oversize. So I will probably not use TBM again for wing tubes. Just my experience. |
Yeah. Call them. I did call them before I placed my order and talked to two different people about needing a slightly oversize tube. They printed me out an invoice with a notation on it about the tube being oversize, and I wrote a note on it making it absoulutely clear. But when I received it and measured it, not only is it NOT oversize, but it is actually about 2-1/2 thousands undersize. So if I call them they will probably tell me to send it back. But I went thru all the hassle so I wouldn't have this problem in the first place and have to send it back. No thanks. I'm so angry at these people, the last thing I want to do is talk to them, and have the expense of shipping it back. Just fed up is all. Don't want to deal with them anymore.;)
I can understand that. Guess it's time to use the old thin CA trick to make the wing tube snug.
Yeah, that might do it. I was thinking of maybe some type of paint also, but thin CA may be more durable. I'll get it to fit properly, one way or the other. Thanks for your suggestion.
ORIGINAL: Gungadin Yeah. Call them. I did call them before I placed my order and talked to two different people about needing a slightly oversize tube. They printed me out an invoice with a notation on it about the tube being oversize, and I wrote a note on it making it absoulutely clear. But when I received it and measured it, not only is it NOT oversize, but it is actually about 2-1/2 thousands undersize. So if I call them they will probably tell me to send it back. But I went thru all the hassle so I wouldn't have this problem in the first place and have to send it back. No thanks. I'm so angry at these people, the last thing I want to do is talk to them, and have the expense of shipping it back. Just fed up is all. Don't want to deal with them anymore.;) Dan this isn't a real big deal. One way to increase diameter is to use light silkspan strip and a touch of epoxy or thin ca. Smooth it out and lightly sand it to fit. You don't really need to do the whole tube, just a couple locations along the length. Do the ends and both areas that will be supported by the fuse sides. We do this all the time as a matter of course to get perfect fits Matt |
Thanks Matt. I'm probably making too much out of it. I may still have some silkspan somewhere.;)
| All times are GMT -8. The time now is 11:45 PM. |
