RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   A Stupid Question (https://www.rcuniverse.com/forum/rc-pattern-flying-101/9736894-stupid-question.html)
Strat2003 05-16-2010 08:02 AM
A Stupid Question
If I put the regulator for my LiPo airborne pack before the switch, will I kill my batterey?
I think I know the answer to this, lol.
cmoulder 05-16-2010 08:41 AM
RE: A Stupid Question
ORIGINAL: Strat2003
The reg should be between the switch and the Rx. Mandatory if you are using a switch with a charging jack... can't charge a battery thru a reg, nor test battery voltage.
apereira 05-16-2010 09:58 AM
Yes.
petec 05-16-2010 10:35 AM
Only if you leave the battery plugged in....Bob's post is right on the money.
Strat2003 05-16-2010 11:10 AM
In the words of the immortal Homer Simpson:
D'oh!
I hate learning by paying for things, lol.
petec 05-16-2010 02:30 PM
I'm sure Rick feels the same way.....thanks for the picture....
mjfrederick 05-17-2010 11:06 AM
In the immortal words of Mr. Garrison: "Remember, children, there are no stupid questions, just stupid people."
petec 05-17-2010 11:29 AM
I use that quote all the time.
Strat2003 05-17-2010 11:33 AM
I resemble that remark!
petec 05-17-2010 11:42 AM
No you don't....according to Rick he was at the field with Dave and some smart guys.....
RC11 05-17-2010 06:48 PM
Smart is only the half of it! Scott, I take it you ran you lipo too low to charge. Sometimes you can carefully trick them back to life charging them slowly with a Nicad progam. Carefully!
RC
cmoulder 05-17-2010 07:03 PM
ORIGINAL: RC11
RC
I have done this a few times, and it does work. Used a NiCd charger to get the voltage up to 3.3v per cell and then quickly switched over to a LiPo charger. The voltage comes back up very quickly (within 3-4 minutes) so you have to sit there and watch it and be ready to switch chargers. I have resuscitated some LiPo's with very low voltage readings... less than 2 volts per cell. The NiCd charger I use is an MRC Super brain 977.
Strat2003 05-18-2010 06:39 AM
I tried tricking the charger by telling it that it was a one cell pack but the voltage was too low even for that. I may try the NiCd setting, but to be honest I don't think I'd trust the battery in an airplane now. I ordered a replacement and it's on the way.
Live and learn.
MTK 05-19-2010 09:58 AM
ORIGINAL: cmoulder
ORIGINAL: Strat2003
I asked Ed Alt to set-up my Tech Aero regulator such that the switch and charging/checking plug were parts of the same harness. In other words, the reg is used in similar fashion to a standard switch...one side connects to the LiPo and the other side to the RX, with switch in between. The charging/checking plug works fine too but I generally remove the LiPo from the airframe while charging.
If anyone is in the market for a new reg, ask Ed to help you out in the same manner
cmoulder 05-19-2010 10:28 AM
ORIGINAL: Strat2003
Live and learn.
Easy enough to run and time it on the ground, taking the occasional voltage reading. Or better yet, with a Super Whatt Meter and monitor all the vitals real-time at various throttle settings.
I won't go too far out on a limb on this, but I think there might be a smidge of mythology behind the notion that overdischarged LiPo's are permanently screwed. The ones that I've resurrected seem to have suffered no ill effects.
petec 05-19-2010 11:54 AM
ORIGINAL: Strat2003
Live and learn.
Bring it to the field tomorrow.
Strat2003 05-19-2010 12:09 PM
And we'll try it in your airplane, Pete? :D
rcpattern 05-19-2010 12:21 PM
ORIGINAL: Strat2003
Live and learn.
I think I'd agree with Scott on this. I wouldn't trust it in an airplane again. It seems as if most LiPo failures are a result of running them too low, crashes, or over-charging. If I have any issue with a LiPo, I'll just get another one. Not worth risking a plane over something this cheap.
Arch
Strat2003 05-19-2010 12:27 PM
I ordered an new battery from Central Saturday evening and it came today (wow!). It's on the charger now. I'll bring the old one along tomorrow, Pete, and if you can get it to come back we'll give it to Rick, lol.
petec 05-19-2010 01:18 PM
Sounds like a plan....Rick will use anything that doesn't say YS on it.
