Smoked Canopy
Hello
I'm searching a product to smoke my canopy. I would like the same effect that on the Axiome but in blue coor. http://www.oxai-rc.com/upFile/detail...6171152267.jpg Anyone know where can I find it? and how to apply thos to have the same color ont the all canopy? Thanks a lot. best regards. Philippe |
RE: Smoked Canopy
If you can get the Testors Candy Blue paint that they use for car bodies, I have used that with good success. Just put a couple of coats on the inside of the canopy and you will get a nice transparent blue. The more coats you put on the darker the blue.
Tim B |
RE: Smoked Canopy
Or Pactra RC272 Candy Blue
RE: Smoked Canopy
ORIGINAL: RCBruski65 If you can get the Testors Candy Blue paint that they use for car bodies, I have used that with good success. Just put a couple of coats on the inside of the canopy and you will get a nice transparent blue. The more coats you put on the darker the blue. |
RE: Smoked Canopy
Hi, Philippe
Generally everybody use chemical colorant for dyeing a clear canopy ( but I have had no experience). How to use of the dyes for resin and so on is as follows. 1 Dilute the dyes with water to 5%. 2 Warm the aqueous solution until 60c degree to 80c degree. 3 Dip a canopy to the warmed aqueous solution. 4 Wash away the canopy with neutral detergent. http://www.osaka-kaseihin.co.jp/syohin.htm Best regards |
RE: Smoked Canopy
Sarashina, I've never had good luck with doing that. I either have ended up with a weakly tinted canopy, or worse, a well tinted warped "thing"
Maybe we have the wrong plastic here in australia. |
RE: Smoked Canopy
Hello
Thanks a lot guys to help me with this canopy. Thnaks a lot sarashina I will send you pics as soo as I will finished my new plane. Best regards. Philippe |
RE: Smoked Canopy
I've used a product found here in the US called RIT dye. It is found at the local grocery stores and its used to dye clothing. It is in a powder form. Just pour it into a bucket of very warm water stir it up and put the canopy in. Its like coloring easter eggs. Good luck.
| All times are GMT -8. The time now is 12:19 PM. |
