RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   ?'s on my tail configuration. (https://www.rcuniverse.com/forum/rc-pattern-flying-101/9911432-s-my-tail-configuration.html)
EscapeFlyer 08-04-2010 07:12 PM
1 Attachment(s)
I am finally committing and will be seriously stepping forward on pattern this next year. I've been building a lot of airplanes, so this is slow in coming, but I am finally getting somewhere.
I will be entering competition, and I have a good airplane to get me going. I'm starting with an Ultra Sport. However, I have made a few minor modifications.
Upon gluing the horizontal, I found that I didn't get it perfectly square, and I just can not live with it. So I have cut it off to fix it with a different option. I have cut a foam stab. I airfoiled it, and cut it aabout as thick as my UFO stab is to slow it down a bit. Then I wanted to add a little anhedral. I know this airplane is fine stock, but I believe it will help take a little pressure of the rudder when the airplane is on its side (as I understand from an article Dave Brown wrote) and resolve the minor inherent pull towards the canopy.
That's my story. Of course, I could be completely wrong, but it sounds good!
Soo, I took a few shots of a static view of what it will look like.
Any opinions?
(Please forgive the mess on the table. I am in the process of re-organizing and cutting a trainer kit from plans for my daughter. I don't like to be messy.)
OBTW- Am I allowed to use a muffled tuned pipe?
Brian
flyncajun 08-04-2010 08:21 PM
RE: ?'s on my tail configuration.
Hi Brian
that plane looks fine
The stab is the last place that would mess up the way an airplane flies , and it wont hurt a thing to add anhedral.
keep the passion and have fun flying pattern
you can use any Exhaust you want :D
Bryan
MTK 08-04-2010 09:09 PM
I agree with Bryan. Finish it and fly it.
On the exhaust, should be reasonably quiet. If the power is a 60, set it up to turn something like a 12x11 apc
On the messy bench....well ....a clean bench accomplishes nothing!!
EscapeFlyer 08-04-2010 10:07 PM
I appreciate that. Thanks! [8D]
I'm anxious to get it flying.
I'll be fiberglassing the fuse, using fabric on the wing, and shooting it with Klass Kote.
Brian
MTK 08-04-2010 10:54 PM
ORIGINAL: Ilikebipes
Brian
Try to keep weight in check. The plane shouldn't weigh much more than about 1 lb per 100 sq inches of wing. Consider film on the wing...it will save you plenty elbies
EscapeFlyer 08-04-2010 10:58 PM
Double Post...
Moderators please delete with my apologies...
Brian
EscapeFlyer 08-04-2010 11:05 PM
The reason for using cloth on the wing is the problem of matching Klass Kote colors to film colors. If I can get a good match with the color paint I want to use and film covering, I'd go this route in a heart beat.
Unfortunately, the options in Lusterkote are very limited and do not hold much interest for me.
I know this rubs a lot of people, and nothing personal against your advice as it is appreciated, but I'm not a firm believer that lighter is always better. A 60 sized Ultra Sport at 7lbs would be nice on a very calm day. I've not seen many perfectly calm days lately. I'm shooting for 8-8.5lbs.
Brian
MTK 08-04-2010 11:31 PM
I'm not rubbed either way. Actually I think it's funny.......
One thing certain, one tiny piece of experience is worth about a million inexperienced opinions, probably more
Good luck
EscapeFlyer 08-04-2010 11:50 PM
I can appreciate that. That is why I don't want a 7lb US.
Thanks.
Brian
Rendegade 08-05-2010 12:19 AM
Better to build light and add ballast where you want it, than to build heavy and not be able get it right.
But, hey what do I know.
EscapeFlyer 08-05-2010 12:28 AM
Unfortunately, I made a mistake by addressing weight issues in the 1st place. This is not the context or my concern in this post. I understand that my opinion steps on a lot of toes, but my drive here is not to offend, which is obviously what I have done by these responses.
Please accept my opinion for what it is. It is based on my experiences only, and I have a preference based on it. I am in no way telling anyone how they need to do anything. I do appreciate the experiences shared with me, but there is "more than one way to skin a cat," and my way is not the only way. It is simply my preferred way and I have respect for opposing opinions on this matter.
I would appreciate it if we can move past this and understand my post. The intent is to find if this configuration in the tail is helpful or a detriment. I like the looks and hope it has some benefits.
Brian
klhoard 08-05-2010 09:02 AM
Brian,
    It's YOUR airplane. . . build it 1 lb. or 50 lbs. . . . <br type="_moz"/>
