Corona Receiver and Futaba
MD
Help, All suggestins appreciated. I have several Corona RP6S1 Synthesized receivers. They will lock onto a Futaba Skysport transmitter with ease. However, when I attempt to lock them onto a Futaba 9C in PPM mode, only one channel functions. When the 9C is in PCM mode the receivers will not even lock on.
Thanks,, Henry
Thanks,, Henry
RE: Corona Receiver and Futaba
Are you using a Futaba frequency synthesized transmitter module? Seems that I remember that there were issues using those receivers with the "dial a crash" module, but that was about 2.4Giga years ago, my memory is getting very foggy, to much exposure to 2.4Ghz waves
Good luck,
Pete
Good luck,
Pete
MD
Fellow pilots FYI, In case this ever happens to you. The problem was solved when I went into the Parameters menu of the 9C for the model I was trying to use and I "Reset" it.
