T14Mz - Futaba Logo blinking Yellow
Hello everybody,
I need assistance,
I own a T-14Mz. Yesterday i decided to install the new Firmware from Futaba.
I had no problem to install the new Firmware. But this morning when i switch on my TX,
The Futaba Logo start blinking in Yellow and the Tx won't boot. After few attempts the Tx goes on, but if i wait 1 hour with the tx off,
I have the same problem.
It seems that the tx won't boot on cold start, but no problem on hot start.
I tried another firmware (French) and same symptom....
What can i do ?
Where can i find the old firmware ?
Thanks in advance for your help and sorry for my bad english...
Yann
I need assistance,
What can i do ?
Yann
RE: T14Mz - Futaba Logo blinking Yellow
Hi Yann,
You really need to post this problem in the Futaba support forum. It's closer to the top of the page. Someone from Futaba will be of more help on this problem.
One thing does come to mind, now that I think about it. Does the T14Z use the yellow logo as a warning light if a mix such throttle cut is active, or if the throttle is not closed when helicopter software is in use. Check the manual to see if the yellow light is an indication of a function being enabled.
Best of luck,
Pete
P.S. your English is fine
Best of luck,
Pete
