Looking for channel 35 JR reciever
Iam looking to buy a 4-8 channelJRFM, PPM, orPCMreciever on channel 35. If anyone has one, or knows where I can buy one please let me know. Thanks!
RE: Looking for channel 35 JR reciever
Talk to allans as it sounds like he has exactly what you need. If you two don't work things out, however:
-You can get JR TX/RX crystal sets from http://www.performancedevices.com to switch JR receivers to your channel.
-You can also simply buy any of the Hitec auto shift receivers and use them with your JR transmitter. You can buy them with the channel crystal of your choice, and Hitec makes channel selectable receivers that don't require crystals for 72Mhz FM/PPM use. The Hitec Supreme IIS receiver, for example, is an 8-channel dual conversion receiver that auto detects positive or negative shift from your transmitter and will work with any Airtronics, JR, Futaba, Hitec, or Tower Hobbies transmitter on 72Mhz FM. It's one of the finest FM receivers on the market, and it's routinely available on sale for $29.99 or thereabout from retailers.
