Tower TS-53 with JR trans/receiver?
I have a cub with 5 new TS-53 servos in it and a Tower system 3000 radio (very limited) that came with it..
Can Ileave userthe TS-53 servos with my JR-6102 TRANS and JR 6 channel reciever? Ichecked operation of a JR servo in with the system 3000 and the rotation is reversed. So at minimum I would have to revers the servos if using the JRtrans/rec.
Is there any other issues with this i need to beware of (couldn't find a post on this using search).
Thank you.
Oldschool.
RE: Tower TS-53 with JR trans/receiver?
ORIGINAL: OldschoolG I have a cub with 5 new TS-53 servos in it and a Tower system 3000 radio (very limited) that came with it.. Can Ileave userthe TS-53 servos with my JR-6102 TRANS and JR 6 channel reciever? Ichecked operation of a JR servo in with the system 3000 and the rotation is reversed. So at minimum I would have to revers the servos if using the JRtrans/rec. Is there any other issues with this i need to beware of (couldn't find a post on this using search). Thank you. Oldschool.
The channel assignment order is different between Futaba & JR, if not shownon JRRX case,
RX...............Channel Assignments as determined by different brands of TX
......................Futaba/Hitec......Graupner/JR
Channel 1....... ailerons.......... throttle
Channel 2....... elevator..........ailerons
Channel 3........throttle............ elevator
Channel 4........rudder............. rudder
The TS-53 is simply a re-badged Futaba S3003 servo and works well with a JR system.
The Futaba J plug is easy to amend to a JR style as per
Servo - Wiring Diagrams = use with other brand RX.
and more at
Alan's Hobby, Model & RC FAQ Web Links
Regards
Alan T.
Thanks for the info.
So in summarry, I can just cut the tab off of the TS-53 servos and plug into the JR receiver and all is good (same wiring configuration (but will need to reverse servos)
Using the Futabo reciever w/ JR trans is out of the question right?
ORIGINAL: OldschoolG Thanks for the info. So in summarry, I can just cut the tab off of the TS-53 servos and plug into the JR receiver and all is good (same wiring configuration (but will need to reverse servos) Using the Futabo reciever w/ JR trans is out of the question right?
Negative and/or positive shift in Transmitters and Receivers - 101 re Differences
regards
Alan.
