dual elevator
My Feedback: (23)
FL
dual elevator
Hi, First I am know radio guru by any means. i have a 9C with 2.4 conversion. I am using a
R617FS receiver and I am not having any luck programming for dual elevators only
Any help would be appreciated.
Keith
Keith
RE: dual elevator
Hi Keith,
You may want to try to this FAQ for the 9C that addresses how to do this with mixes:
http://www.futaba-rc.com/faq/faq-9c-q512.html
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Sincerely,
Krysta
[email protected]
RE: dual elevator
OK, I have the mix setup in front of me. You can't use ailevator mix with a seven channel receiver, but no biggie.
Prog Mix.
ELEV to GEAR
RATE -100% -100%
OFFSET 0%
MIX ON
MAS 2:ELEV
SLV 5:GEAR
LINK OFF
TRIM ON
SW don't matter
POSI NULL
That will do it, and trim will be active for both halves of the elevator.
Good luck,
Pete
Prog Mix.
ELEV to GEAR
RATE -100% -100%
OFFSET 0%
MIX ON
MAS 2:ELEV
SLV 5:GEAR
LINK OFF
TRIM ON
SW don't matter
POSI NULL
Good luck,
Pete
