Spoilerons
TX
Spoilerons
I have a sailplane - v-tail with ailerons(2 servos on ailerons, 2 servos for the V-tail). The radio I have is a Futaba 6XAS.
I would like to convert to spoiler-ons. I am told I should use PMIX1 and PMIX2 to do this. Can somebody help me with this set up. The manual in not very clear. Currently I have it set up for V-tail only.
Thanks in advance
Thanks in advance
RE: Spoilerons
I have a 6XAS but I'm not sure of the exact proceedure. But what you want to do is plug one servo into channel 1 and one into channel 5 (Flaps)
Check to see if that Tx has a Flapperon function. If it does, there might be a parameter that allows you to reverse the setup so that when you turn channel 5 on, the ailerons will go up instead of down.
