FUTABA 10c BATTERY LIFE
I have a futaba 10c it came with a 700 mah which is useless
I have to charge the battery every few flights any suggestions
on what size battery I can use............... thanks...... John
RE: FUTABA 10c BATTERY LIFE
ORIGINAL: caseyairbus
I use 3cell 2500mah LiPos for Tx batteries in my JR XP9303. I do not have a 10C so I do not know if it will tolerate the 12.6v fully charged 3cell LiPo. Some people install special Diodes in line with the battery leads to the Tx. Each Diode drops the voltage .3v. Some use two in series.
What I like is the charge takes less than an hour and I don't have to recharge for weeks.
Some also use LiFe batteries which operate at 3.3v/cell.
If you have to charge every few flights, somethin ain't right. The stock 700mAh Nicad should give over 2 hours of run time. Are you using a peak detecting charger, instead of the stock wall wart over night charger? If so, try leaving the radio on the stock charger for at least 14 to 16 hours, then see if you get more run time.
A replacement Eneloop pack would be a very good choice, probably giving about 8 hours of run time on a charge.
Good luck,
Pete
Good luck,
Pete
Something is not right if you only get short battery life,replace the battery. I do not recommend using Li Po in TX although some folks do. Use a 1500 Ma NiMh and all will be fine.
hi guys,
thanks for all the help, I think a lot of people misunderstood what I said, even me
it's not that 3 different Jets I use this radio I normally get between 3 to 6 flights
and then I have to wait and recharge what I want to know is does anybody have
a futaba 10c with lipo batt and what size and will it fit..................john
hi guys,
hi guys,
If you had to, you can Fly, Charge in between flights, and Fly. You can fly indefinitely using this method. After 33 years of flying with NiCads and NiMh batteries, dealing with the slow recharge rates and the self discharge, there is really no reason to ever go back to NiCad or NiMh. LiPo, LiFe, and Eneloop are the way to go. Soon, there will be even better choices as battery technology develops.
MB, CANADA
I bought the 2000 mah eneloop's and they work very well. Keep their charge very well too.
http://www.hangtimes.com/txpacks.html
My Feedback: (41)
hi guys,
hi guys,
http://www.hobbyking.com/hobbyking/s...idProduct=7346
hi guys,
hi guys,
Hi, caseyairbus...
I have the T10C with lipo and it works flawlessly.
You should place 2 diodes in series to have a voltage drop from 1.5 to 1,8 v,
so that the alarm of T10C works properly.
I used 2 pairs(diodes) in series and parallel on each other, so even if one of them fails (burns)
randomly, the circuit will continue to be powered ....
Otherwise if the T/x suddenly go out of power while flying ...... [&o]
The battery is from the known Chinese seller, specially constructed for T/x rated for low C discharging.
It comes with 3 cables, 1 for Futaba ,1 for JR plus 1 for the balanser.
I removed the JR plug and added there, a tiny board with the diodes plus another plug for Futaba.
The new plug gives power to T/x through the diodes.
The original Futaba plug is used for the charging....
....This circuit gives me a voltage drop of 1,8 v.
The Futaba alarm rings at 8,5 v + 1,8 v = 10,3 v.
You charge the lipo at full power and when the voltage falls to 10.3 (safely), the Futaba alarm is ringing .
The good thing is that ....... You charge...... and it .....Holds.............!!!!!!!!!!!!
My Feedback: (41)
I just plug mine in direct. Works great. No diodes. Buddies in my club have been doing this on the 9C for years. Almost 5 years? Not one single problem. Now we all have them on our 10C's no problems. What I do is use the timer to let me know when to charge. Once it gets to 15 hours it gets to around 11 volts. Then I start thinking about recharging. But I went to 17 hours and 10.7 volts last time since I was just setting up a plane at home.
