mixing two channels for throttle on 9C
I am doing somthing wrong slaved 5 to 3 mix on, link on, trim on, and switch null. I have the rate at -100% down and +100% up off set 0% channel three throttle works but channel 5 doesn't can swap esc around and the all work so I know the ESCs all work.
RE: mixing two channels for throttle on 9C
Well I unplugged the ESCs and used 2 servos and found I needed to change the rate to +100% up and down with the offset at 50%, all 4 motors are now just singing together making beutiful music, yipee
