DX 8 with analog and digital servos
What frame rate do you set up in the DX 8 when using digital and analog servos on the same plane?? 11ms or 22ms?? Thanks.
RE: DX 8 with analog and digital servos
If the digitals are on aileron, elevator, and Aux1 (usually left aileron) then you can use 11ms frame rate. The 11ms is only for those 3 channels, all the others get 22ms frames to the servos.
Andy
Andy
