Hitec HS 5645-MG servo that's acking weird.
NV
HS 5645MG is not going all the way forward. It seams to move about 60-70% then stops. And it re-centers it's self with the push rod hooked up to the flap. But if I unhook the push rod, it sticks. If I lighty pull the arm, it's will center. It doesn't take much presure, just a little. Could it be a bad gear set, or something on the endside?
