Wiring help for separate retract batt for JR S791
Old 05-23-2011, 04:50 AM
sodbuster 1
sodbuster 1's Avatar
Default Wiring help for separate retract batt for JR S791
Am using a JR S791 retract servo that only runs on 4.8V.
Am using a 6V pack for the RX supply on an AR7000 to supply control surface servos.
Am using a separate 4.8V pack run thru a switch to supply the retract servo so in case of a retract issue RX pack won't draw down or go into brownout.
2 QUESTIONS.
Will running 6V to the RX cause any issues as far as the signal to the servo?
Is my wiring schematic correct for hooking this up?
Old 05-23-2011, 08:48 AM
crossman
Default RE: Wiring help for separate retract batt for JR S791
You will also need to connect the black wire to the RX. Without it, there will not be a complete circuit for the pulse. As long as the red is separate, the batteries will be isolated.
Old 05-23-2011, 02:01 PM
A.T.
ORIGINAL: sodbuster 1 Am using a JR S791 retract servo that only runs on 4.8V. Am using a 6V pack for the RX supply on an AR7000 to supply control surface servos. Am using a separate 4.8V pack run thru a switch to supply the retract servo so in case of a retract issue RX pack won't draw down or go into brownout. 2 QUESTIONS. Will running 6V to the RX cause any issues as far as the signal to the servo? Is my wiring schematic correct for hooking this up?
Previous answer + 1, following may also assist:
<dt>
Separate Battery for Retract Servo - DIY harness. 01
</dt><dt>Separate Battery for Retract Servo - DIY harness. 02
and much more under sub section
"Retract Undercarriage, Flaps and payload release" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T. </dt>
Old 05-23-2011, 02:16 PM
sodbuster 1
Thanks Chuck.
Thanks Alan. Wish I'd have thought of using a Y connector before I cut up my switch lead to solder the RX input to it..good schematic.
Old 05-23-2011, 05:23 PM
airbusdrvr
Here is a diagram I have for your question. Might be like the others, I didn't go to the links.
Old 05-23-2011, 06:29 PM
BuschBarber
ORIGINAL: airbusdrvr
Yes!! That looks like the other diagram.
